Port scanning by Plusnet DNS server?
- Port scanning by Plusnet DNS server?
10-09-2014 12:08 PM
Last night, earlier this morning, and currently I have had a few dozen emails, some of which relate to the usual suspects, but many are as follows:
[DOS] UDP Packet - Source:212.159.6.10,53 Destination:XX.XXX.XXX.43,55014 (my current IP address)
The source appears to be PlusNet's own "additional DNS" servers which seems pretty weird to me - does anyone have any idea what might be going on here?
The router is set to use 8.8.8.8 and 8.8.4.4. and has been for years - nothing else has been tweaked or altered either.
Re: Port scanning by Plusnet DNS server?
11-09-2014 9:06 AM
Could a member of the PlusNet support team please check whether this is a 'feature' of my current IP address, which I obviously don't want to post here?
I shall try to obtain a new address if you believe that may solve the problem.
11-09-2014 9:14 AM
17.173.254.222 is Apple's iMessage server I believe.
11-09-2014 9:23 AM
Quote from: AndyH This is their DNS servers - 212.159.6.10 It's not port scanning you, it's respond to your DNS lookup request.
The router is set to only use Google DNS servers - why would it be trying to look up using PN servers?
11-09-2014 9:35 AM
Are you sure the router is set to use Plusnet's DNS servers?
11-09-2014 9:44 AM
11-09-2014 9:46 AM
Have you rechecked the dns settings in your trusty netgear?
Is it running custom firmware by any chance?
11-09-2014 10:11 AM
No custom firmware (currently 5.01.16 although I note that 5.01.17 was released earlier this year which "fixed TCP port 32764 issue", which I must admit is way beyond my level of IT knowledge to be able to understand the possible implications of it!)
11-09-2014 10:34 AM
ipconfig /all
Also the router may well be using the dns servers (plusnet's) assigned via dhcp for it's own internal lookups. eg to resolve things set in the router like the time server etc.
11-09-2014 10:38 AM
11-09-2014 10:50 AM
If I continue to have problems I'll be trying your suggestions - thanks very much for your help so far.
