Plus Net and Sky Anytime+
- Plus Net and Sky Anytime+
- « Previous
- 1
- 2
- Next »
Re: Plus Net and Sky Anytime+
10-04-2012 6:56 AM
Hello,
I thought that would be the case but it always easy to blame somebody else. Sky have washed there hands of this saying that there is nothing more they can do.
I am using a Linksys WAG320N with both NAT and the firewall off. I have my own gateway / firewall setup using a SME sever. It is a standard firewall setup The only thing left to try is connecting directly to the Linksys which needs some rewiring.
Message 16 of 19
(350 Views)
10-04-2012 9:36 AM
Quote from: Docrob Hello,
it is not a case of PN washing their hands off it. They have no case to answer. Also as well as using sky go my daughter uses anytime plus on her ipad 2 with no problems. Mine is a fairly standard setup with a d-link 2740-r modem/router using it's own firewall. I would tend to take a closer look at your own setup as it could be the gateway where the problem lies. Doing what you suggest will rule it out.
Message 17 of 19
(350 Views)
10-04-2012 3:05 PM
I've just set mine up in seconds using a homeplug to connect to the router and then signing up on line. It seems to be working fine. (Now I only need to work out how to get it to download between 12:00am and 8:00am )
Message 18 of 19
(350 Views)
10-04-2012 3:20 PM
Quote from: harps1h
Quote from: Docrob Sky have washed there hands of this saying that there is nothing more they can do.
it is not a case of PN washing their hands off it. They have no case to answer. Also as well as using sky go my daughter uses anytime plus on her ipad 2 with no problems. t.
1. Please note my post said SKY not plus net I fully understand that they are not at fault I would have raise a Ticket rather than asking in the forum otherwise.
2. Sky Anytime plus works via the Sky HD Box and TV. Sky go works on an IPAD it also works on my iMac and macbook pro. Basically it is streaming via a web page.
Message 19 of 19
(350 Views)
- « Previous
- 1
- 2
- Next »
