PPPoA or PPPoE
- PPPoA or PPPoE
PPPoA or PPPoE
17-09-2012 1:35 PM
I've just realised that the last two modem/routers I've used have connected to PN using PPPoE.
The documentation I was supplied by PN a few years ago tells me to connect using PPPoA.
If I reset the router to PPPoA it syncs to the exchange but will not connect to the internet even after I have power cycled it.
Is this normal ?
Oldgeezer.
Is this normal ?
Oldgeezer.
Message 1 of 2
(679 Views)
1 REPLY 1
Re: PPPoA or PPPoE
17-09-2012 2:01 PM
No, but I have seen this before. In the days when AOL used PPPoE I also saw the inverse, when only PPPoA worked on the odd line.
Message 2 of 2
(293 Views)
