POP3 e-mail
- POP3 e-mail
POP3 e-mail
06-09-2008 5:02 PM
Hi, appears to be broken and has been all day, I get this message from outlook:
Task '**** - Receiving' reported error (0x80042108) : 'Outlook cannot connect to your incoming (POP3) e-mail server. If you continue to receive this message, contact your server administrator or Internet service provider (ISP).'
Task '*** - Receiving' reported error (0x80042108) : 'Outlook cannot connect to your incoming (POP3) e-mail server. If you continue to receive this message, contact your server administrator or Internet service provider (ISP).'
I checked webmail and I've messages in there from 1:54am this morning.
Thanks...
Chris
Thanks...
Chris
Message 1 of 6
(1,273 Views)
5 REPLIES 5
Re: POP3 e-mail
06-09-2008 5:06 PM
No problem with me, just this minute got my messages via pop3
Paul
Paul
Message 2 of 6
(521 Views)
Re: POP3 e-mail
06-09-2008 5:12 PM
Hi, thanks Paul, mine seems to now been working, tried earlier on and had this message as well. Must be fixed now unless it is an intermittent problem...
Chris
Chris
Message 3 of 6
(521 Views)
Re: POP3 e-mail
06-09-2008 5:43 PM
It seems to be OK for me, but I did have a few problems earlier - sending email using authenticated SMTP, where I had to try 3 or 4 times before it would accept my password.
Tony
Tony
Message 4 of 6
(521 Views)
Re: POP3 e-mail
06-09-2008 7:10 PM
SquirrelMail has been giving me an error all day for Force9.
Message 5 of 6
(521 Views)
Re: POP3 e-mail
07-09-2008 1:47 PM
It looks like there may have been some DNS issues which might have accounted for this (nothing on the service status)
See DNS Response Times
[Edit] the problems have now scrolled off the end of the graphs, but there was a 2 to 3 hour period around 17:00 on the 6th when the response times on all of the DNS graphs went off the scale.
Tony
Tony
Message 6 of 6
(521 Views)
