Once again peak time comes and speed drops like a stone
- Once again peak time comes and speed drops like a ...
21-02-2013 5:59 PM
I've tried jumping to numerous gateways but nothing seems to alleviate it, and I'm guessing it's down to my exchange being Amber with no sign of a fix from BT.
Re: Once again peak time comes and speed drops like a stone
21-02-2013 6:01 PM
21-02-2013 6:21 PM
BUT because I've been having recent problems with my noise margin of an evening, I'm checking my stats/speed occaisionally, & have noticed the past two nights that speed after as you say around 1800 suddenly drops.
This has ONLY happened since Monday, prior to that I've had reasonable speed when my SNR was on or above 3dB but tonight I got around 1.4, and last night 0.9 ish.
Methinks BT/Plusnet have a major problem on their hands.
21-02-2013 7:19 PM
Usually that is what causes the slowdown on adsl connections.
21-02-2013 9:46 PM
22-02-2013 7:13 AM
22-02-2013 7:45 AM
22-02-2013 7:49 AM
22-02-2013 7:55 AM
If there is no line fault and PN say they have no bandwidth issues, then it pretty much has to be down to your exchange/BT's 21CN network. Btw, I found that the most congested times were 9:30-10:30, 14:00-14:45, 16:15-17:15 and 20:00-21:30. If you are seeing slow downs then (like I was), I would say it is BTs network.
22-02-2013 8:17 AM
However - I see very little new building in this area (theres very little space left for it - and I'm guessing most people already have BB, so I don't quite see how the exchange can be having more lines put in on tthe BT equipment.
22-02-2013 8:31 AM
I think the uptake of fibre has been so fast, that BT's network has been caught out in areas. Also the change of BT Infinity to an unlimited service a few weeks ago would surely have out more pressure on their network.
22-02-2013 8:41 AM
22-02-2013 8:50 AM
22-02-2013 8:56 AM
22-02-2013 10:59 AM
http://usertools.plus.net/exchanges/?exchange=Thornley&exact=2367&plugin=vp
To be honest though I only started getting this crappy evening performance in the last few weeks.
