Odd Fault
pjmarsh
Fixes: 21
Odd Fault
Hi
I've currently got a problem which seems quite strange to me.  My router disconnected today and when trying to reconnect is getting Authentication Failed (no details have changed on the router).  If I try the username from a different Plusnet account (I have quite a few different broadband connects!) it connects fine without a problem.  I've been on to support for nearly an hour and we've tried other routers with the same results.  bt_test_user@plusdsl.net (and bt_test_user@plusdsl2.net) also fail authentication.  Support has raised it as a fault and has escalated it for an engineer visit, but I'm unsure how it could be BT related as other users (on the same domain) works without an issue.
For some time I've been using plusdsl2.net as the domain, but we've been trying both that and plusdsl.net.
Anyone got any suggestions?
Phil
9 REPLIES 9
mikehiow
Re: Odd Fault
I'm pretty sure the bt test account is bt_test_user@startup_domain?
It could be an issue on the BT radius servers but It seems incredibly odd that yours fails and others don't, though - have you tried this account on one of your other connections?
pjmarsh
Fixes: 21
Re: Odd Fault
Hi Mike
bt_test@startup_domain worked without an issue.  The guy on support told me to then try the other ones.  I've not tried my account on one of the other connections yet.  They are all in other locations, so may drive out to one and give it a go later on.
Phil
pjmarsh
Fixes: 21
Re: Odd Fault
Hi
I've tried the username and password on a different PlusNet line and get the same authentication errors, so it is definitely not down to my line!
Phil
pjmarsh
Fixes: 21
Re: Odd Fault
I'm not sure how it would make any difference, but I've just tried again on a different Plusnet line connected to a totally different exchange, still with the Authentication Failed issues.  I'm sure if Plusnet did a dial test they would be able to see the same thing.
Phil
orbrey
Re: Odd Fault
Hi Phil,
Sorry about that - hoping that with the help of Dave we've got this sorted, if you change the realm in your router back to plusdsl.net that should sort things for you (and get you your static IP back Smiley )
Hope that helps.
pjmarsh
Fixes: 21
Re: Odd Fault
Thanks Matt, I'll give it ago later on this afternoon when I get home.
Phil
pjmarsh
Fixes: 21
Re: Odd Fault
Thanks Matt (and Dave), that seems to have done the trick.  What was it?
Phil
orbrey
Re: Odd Fault
We did some session steering work recently in order that we'd be able to balance the 20CN connections on our gateways. This unfortunately broke the plusdsl2.net realm - granted unintentionally, but there were only a handful of users still connecting on it and we think we've caught them all now.
pjmarsh
Fixes: 21
Re: Odd Fault
Thanks Matt.
Phil
