No Internet :(
- No Internet :(
Re: No Internet :(
16-04-2009 4:44 PM
Whats my next move as i'm tired of playing ticket tennis and not seeing a reply i want lol
Re: No Internet :(
16-04-2009 4:51 PM
Re: No Internet :(
16-04-2009 5:04 PM
Thanks thou itsme
Re: No Internet :(
16-04-2009 5:30 PM
Quote rcvd [CHAP Challenge id=0x1 <4f60f6cf94a1614c9a0fb2a9c3495b80>, name = "bras-red2.mqd"]
Looks like i'm on reading
EDIT
But that RAS does not route through my exchange SMBT , milton keynes , but Bletchley does have a RAS and thats where i am , but it does serve newport pagnel but thats north milton keynes 15 mile away from me
Re: No Internet :(
16-04-2009 6:55 PM
The poor carrier frequencies sounds like a noisy line really, but if you've tested other equipment then we'll have to get an engineer out to test from your premises.
Re: No Internet :(
16-04-2009 7:27 PM
Re: No Internet :(
16-04-2009 8:35 PM
Quote Hmmm... I suspect the lack of connection on startup_domain is something to do with being on the ADSL2 network
But why does the RAS show Reading when that does not even supply SMBT (Milton Keynes) exchange ? or is it more complicated than that .
Mark
Re: No Internet :(
16-04-2009 8:56 PM
Re: No Internet :(
16-04-2009 9:58 PM
Bletchley RAS serves Milton Keynes (SMBT) , so the question is why is my RAS Reading , maybe this is the cause of non connection , being as i can connect to the BT test login and retrieve DNS and an ip , i guess this is Plusnets problem with routing me .
EDIT: Birmingham does as well (serve milton keynes) and ealing ,llford, kingston,
Re: No Internet :(
16-04-2009 10:52 PM
Re: No Internet :(
16-04-2009 11:40 PM
Back to square 1 in theory's.
Re: No Internet :(
16-04-2009 11:40 PM
As WBC use a different backhaul will they be using the same Radius setup? The WBC interconnection for Milton Keynes is Milton Keynes, information gathered from here
Re: No Internet :(
16-04-2009 11:44 PM
Quote from: itsme As WBC use a different backhaul will they be using the same Radius setup?
That was exactly my thought behind the lack of connection on startup_domain, I'd have thought there'd be another test login for the RAS for WBC to test connections. I'll make sure to check on that.
Re: No Internet :(
17-04-2009 9:36 AM
This won't change the status of the fault, we still need to arrange an engineer visit, but it would be good to know from a diagnostics point of view.
Re: No Internet :(
17-04-2009 9:42 AM
Cant remember if i tried that one or not , i'm at work as well so no access at all i'm affraid .
Why an engineers visit clearly as i'm in sync and the phone is working correctly its an exchange problem or the network between BT and Plusnet ?.
I'll pop out in a bit and try .
Mark
adie:quote
