New to plusnet
- New to plusnet
New to plusnet
18-06-2013 12:32 PM
I have to say I have been impressed [so far] all the hardware arrived in a week, the router activation could not have been easier, I remember going from dial up, to broadband then wifi, buying my own netgear router, also my download speed has increased.
So well done plusnet, glad I switched
Re: New to plusnet
18-06-2013 5:09 PM
Re: New to plusnet
18-06-2013 5:59 PM
Plusnet support is sub par compared to O2/BE, Im still waiting for a reply to my ticket.
Sorry I switched.
Re: New to plusnet
18-06-2013 6:04 PM
Re: New to plusnet
19-06-2013 10:42 AM
Sorry to hear you feel that way, I can see you raised this on the 14th. Leave this with me and I'll do my best to get this some attention today, I'm certain we can get this fixed for you.
Adam
Re: New to plusnet
19-06-2013 1:19 PM
The general impression I get from Plusnet is, well its still fast enough so no problem.
Re: New to plusnet
19-06-2013 1:41 PM
It should also noted from what I'm lead to believe As more subscribers take up Fibre then the potential for cross take increases, potentially degrading line quality and speeds as take up increases. I think the plusnet original speed estimates do take this future potential cross take in to account.
Re: New to plusnet
19-06-2013 2:32 PM
@kevinandrews is spot on with that explanation. More specific to yourself I've checked and our profile for the downstream speed is in line with BT's so there's nothing we can adjust for you I'm afraid.
Bearing in mind that DLM should uplift the speed when the connection remains stable your connection has seen a few drops of late, is that anything you're aware of?
I'd say it's fault time if not http://faults.plus.net
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13716485352146.png"/>
Re: New to plusnet
19-06-2013 2:56 PM
Re: New to plusnet
19-06-2013 5:18 PM
Thanks for the replies. I am aware of the session drops in the radius graph, The ones on the12/06/13 were caused by the failure of a new router I purchased as a replacement for the Plusnet one.
The router, a Cisco EA4500 just would not play ball with certain sites, so those dropped sessions were caused by resetting of the router. The rest of the dropped sessions were caused by the bedding in of a TPLINK WDR3600 (Cisco replacement).
Despite their faults, my last isp, Sky, their connection was not affected by dropped sessions (confirmed by tech support) but only on numerous reboots of BT box.
Re: New to plusnet
19-06-2013 5:21 PM
Re: New to plusnet
19-06-2013 6:04 PM
I am also aware that speed drops/latency issues can be caused by new subscribers at the cabinet (ours: ECI 128 Line).
A loss of 20Mb/5Mb and 10ms does seem a bit steep,
Re: New to plusnet
20-06-2013 10:31 AM
Quote I am also aware that speed drops/latency issues can be caused by new subscribers at the cabinet (ours: ECI 128 Line).
I'd not worry too much about that as we've not really seen any evidence to support that but it's something I'm sure we'll keep in mind and be vigilant for.
