New DLM on 21CN ADSL1
- New DLM on 21CN ADSL1
- « Previous
- Next »
Re: New DLM on 21CN ADSL1
05-09-2011 8:47 PM
Thanks Matt... I am aware of what the DLM does,my question is what is DLM quantisation. I have noticed that my BT IPProfile is an odd number, see below, but my plusnet profile is lower than this, at 6Meg. the BT profile seems to be a certain percentage of the line profile. Is this a correct assumption, and should the Plusnet profile be the same or above the BT profile now....
Sync Speed is 7118 at the min, and has been since 30/07/11
PS Router is connected via screened RJ11 cable direct to the master socket fitted with a filtered faceplate.
Message 31 of 34
(247 Views)
05-09-2011 10:42 PM
Using the search on the forum throws up these
http://community.plus.net/forum/index.php/topic,95523.msg805380.html#msg805380
http://community.plus.net/forum/index.php/topic,95625.msg806106.html#msg806106
Message 32 of 34
(247 Views)
06-09-2011 12:38 PM
To add - after a power cut my sync speed went to silly levels
Noise Margin: 5.3 dB
Connection Rate: 5536 Kbps
Line Attenuation: 51.0 dB
Power: 19.5 dBm
Max Rate: 5824 Kbps
This is the current stats after 20 minutes
Noise Margin: 3.0 dB
Power: 19.5 dBm
Max Rate: 5824 Kbps
This is the result from the BT speedtest also after 20 minutes at the higher speed - note that the speed is limited by the Plusnet profile set manually by Jojo at 4500kbps
This means that under the new system the profile change is almost instantaneous - that is going to really muck up the Plusnet mirror
Power: 19.5 dBm
Max Rate: 5824 Kbps
Power: 19.5 dBm
Max Rate: 5824 Kbps
Message 33 of 34
(247 Views)
06-09-2011 8:17 PM
Message 34 of 34
(247 Views)
- « Previous
- Next »
