My Exchange 21CN WBC enabled
- My Exchange 21CN WBC enabled
- « Previous
- Next »
Re: My Exchange 21CN WBC enabled
06-01-2012 3:58 PM
06-01-2012 4:02 PM
To be is to do - Kant
do be do be do - Sinatra
06-01-2012 4:12 PM
06-01-2012 4:31 PM
thanks for the assistance
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
4624 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 4624 Kbps
For your connection, the acceptable range of speeds is 2000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :5816 Kbps(DOWN-STREAM), 440 Kbps(UP-STREAM)
IP Profile for your line is - 5130 Kbps
Upload Speed
352 Kbps
0 Kbps 440 Kbps
>Upload speed achieved during the test was - 352 Kbps
Upstream Rate IP profile on your line is - 440 Kbps
06-01-2012 4:36 PM
06-01-2012 4:51 PM
06-01-2012 4:56 PM
06-01-2012 5:02 PM
Ill give it a go when the sun comes up tomorrow morning I have Routerstats running and its 6.5 at the mo
06-01-2012 5:29 PM
I'm just wondering, as you said -
Quote from: PeterLoftus I feel a good "hacking session" coming on
- whether it would be worth you getting/using a router where YOU can set the target SNR figure, in light of Jelv's comment "It looks like your target noise margin is 9".
I've have bought a couple of Netgear DG834GT on eBay recently, brand new in box with all the accessories, for £8 including P&P - then FLASHed them with "DGTeam" firmware - where you can PERMANENTLY set your target SNR level.
Might be worth a try, and if it doesn't make any difference you will have a decent router and a spare (for backup) for hopefully less than a tenner !
Just a thought
06-01-2012 5:41 PM
- « Previous
- Next »
