My Broadband = 2MB, Flat below = 6.5MB? Help please!
- My Broadband = 2MB, Flat below = 6.5MB? Help pleas...
Re: My Broadband = 2MB, Flat below = 6.5MB? Help please!
26-10-2007 4:17 PM
connected everything to the main BT socket.
Plus nothings changed in the flat in the last 5 months, yet 5 months ago I had 8MB!
Cheers Jameseh.
26-10-2007 5:19 PM
Regards .....
28-10-2007 10:28 PM
ADSL Link - Downstream Upstream
Connection Speed - 2656 kbps 448 kbps
Line Attenuation - 32 db 15.5 db
Noise Margin - 12 db 12 db
Do they suggest the attenuation problem is fixed? The noise margin shows better on this router too, odd.
I've upgraded to BBYW Pro by the way, still getting the same pings, but less usage then my old package. 😕
29-10-2007 9:11 AM
Do you notice any sync speed fluctuation when doing a few reboots? My sync speed seems to fluctuate between 5-7Mbps (sorry to rub it in!) and I was just wondering if you noticed similar fluctuations on your line.
The changes from 6-->12dB shouldn't be enough to force your sync speed down that low.
29-10-2007 12:21 PM
Only between 2600kbps and 3200kbps though.
29-10-2007 1:01 PM
BTs DLM system is supposed to intelligently adapt to improvements in the line. I suspect that your old router had a fault, given the upstream attenuation figures. Can you bear with it for a couple of days and see if you notice a reduction in the noise margin? If not, I can raise a separate fault to BT.
29-10-2007 1:26 PM
Connection Speed - 5888 kbps 448 kbps
Line Attenuation - 21 db 5.5 db
Noise Margin - 11 db 24 db
Guessing that's the higher attenuation you talked about!
HOWEVER, it's still only downloading at 240kb max,
from lots of tests and servers
Fran.
29-10-2007 1:32 PM
Definitely sounds promising!
29-10-2007 2:15 PM
ADSL Link Downstream Upstream
Connection Speed 3648 kbps 448 kbps
Line Attenuation 32 db 15.5 db
Noise Margin 10 db 12 db
Odd!
29-10-2007 2:27 PM
Keep an eye on it and see what sort of sync speed fluctuations you get.
29-10-2007 3:51 PM
There are 8(b)its in a (B)yte.
873kBps x 8 = 6,984 kbps
So you have 6.9mbps, hell call it 7mbps it's close enough
29-10-2007 3:59 PM
Think you might have missed the last two pages of the thread
29-10-2007 5:51 PM
My router is saying it's been connected for 4 hours, but it was at 3232kbps last time I checked, now it's at 2976kbps?
I thought it couldn't...
29-10-2007 5:59 PM
I've had a look at our RADIUS logs and you've been logged in for the last 4 hours
29-10-2007 6:10 PM
The noise margin (DS) started going down, went to 0db.
Then when back to about 11db but sync speed was 2976 instead of 3232 😕
All this time I was still surfing!
