Mid Afternoon Dropouts
- Mid Afternoon Dropouts
Re: Mid Afternoon Dropouts
09-10-2014 9:30 AM
09-10-2014 10:05 AM
I've just checked and Interleaving is now reporting as OFF
Andy
09-10-2014 10:35 AM
still looks like no FEC errors.
? actual zero errors or could it be a problem with the stat grabber querying the modem? Although I guess reporting zero means it did obtain a report?
09-10-2014 12:09 PM
09-10-2014 12:19 PM
The FECErrors count is presumably the downstream end, the TP-Link, and ATUC refers to the "central" i.e. exchange end, so ATUCFECErrors would be upstream FEC errors.
I'm not exactly sure how you managed to get an upstream speed higher than 888 when interleaving was on, but I suppose it may depend on the level of interleaving and other framing parameters or the INP level.
If telnet access to the router allows you to get to a shell, them you would be able to get full stats from the xdsl or xdslcmd command.
09-10-2014 12:26 PM
09-10-2014 12:29 PM
Interleaving is off on the up and downstream
09-10-2014 7:22 PM
[1,0,0,0,0,0]0
enable=1
status=Up
modulationType=ADSL_2plus
lineEncoding=
dataPath=Fast
interleaveDepth=0
lineNumber=0
upstreamCurrRate=1279
downstreamCurrRate=13483
upstreamMaxRate=1276
downstreamMaxRate=14568
upstreamNoiseMargin=57
downstreamNoiseMargin=91
upstreamAttenuation=173
downstreamAttenuation=300
upstreamPower=126
downstreamPower=0
ATURVendor=
ATURCountry=
ATUCVendor=
ATUCCountry=
totalStart=125797
showtimeStart=60723
quarterHourStart=0
X_TP_Bitswap=On
X_TP_SRA=On
X_TP_AdslModulationCfg=Multimode
X_TP_AnnexType=Annex A/L
X_TP_SupportAdslMode=T1.413:A;G.lite:A;G.dmt:A;ADSL2:A,A/L;ADSL2+:A,A/L,M,A/L/M;Auto Sync-up:A,A/L,M,A/L/M
[1,0,0,0,0,0]1
receiveBlocks=0
transmitBlocks=0
cellDelin=0
linkRetrain=0
initErrors=0
initTimeouts=0
lossOfFraming=0
erroredSecs=0
X_TP_US_ErroredSecs=0
severelyErroredSecs=0
X_TP_US_SeverelyErroredSecs=0
FECErrors=0
ATUCFECErrors=0
HECErrors=2709
ATUCHECErrors=112
CRCErrors=524
ATUCCRCErrors=110
[2,0,0,0,0,0]1
receiveBlocks=0
transmitBlocks=0
cellDelin=0
linkRetrain=0
initErrors=0
initTimeouts=0
lossOfFraming=0
erroredSecs=0
FECErrors=0
ATUCFECErrors=0
HECErrors=2709
ATUCHECErrors=112
CRCErrors=524
ATUCCRCErrors=110
[3,0,0,0,0,0]1
receiveBlocks=0
transmitBlocks=0
cellDelin=0
linkRetrain=0
initErrors=0
initTimeouts=0
lossOfFraming=0
erroredSecs=0
FECErrors=0
ATUCFECErrors=0
HECErrors=2709
ATUCHECErrors=112
CRCErrors=524
ATUCCRCErrors=110
[error]0
13-10-2014 10:17 AM
Might a restart do anything?
Upstream Downstream
Current Rate (Kbps) 1279 13483
Max Rate (Kbps) 1280 14728
SNR Margin (dB) 5.9 9.4
Line Attenuation (dB) 17.3 30
Errors (Pkts) 0 0
Download speed achieved during the test was - 11.46 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 11.9 Mbps
Upload speed achieved during the test was - 1.05Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
2014.10.13 10:17:09 xDSL Stats:
[1,0,0,0,0,0]0
enable=1
status=Up
lineEncoding=
dataPath=Fast
interleaveDepth=0
lineNumber=0
upstreamMaxRate=1280
downstreamMaxRate=14708
upstreamNoiseMargin=59
downstreamNoiseMargin=94
upstreamPower=126
downstreamPower=0
ATURVendor=
ATURCountry=
ATUCVendor=
ATUCCountry=
totalStart=93439
showtimeStart=373965
quarterHourStart=0
X_TP_Bitswap=On
X_TP_SRA=On
[1,0,0,0,0,0]1
receiveBlocks=0
transmitBlocks=0
cellDelin=0
linkRetrain=0
initErrors=0
initTimeouts=0
lossOfFraming=0
erroredSecs=0
FECErrors=0
ATUCFECErrors=0
HECErrors=73044
ATUCHECErrors=723
CRCErrors=7419
ATUCCRCErrors=528
[2,0,0,0,0,0]1
receiveBlocks=0
transmitBlocks=0
cellDelin=0
linkRetrain=0
initErrors=0
initTimeouts=0
lossOfFraming=0
erroredSecs=0
FECErrors=0
ATUCFECErrors=0
HECErrors=73044
ATUCHECErrors=723
CRCErrors=7419
ATUCCRCErrors=528
[3,0,0,0,0,0]1
receiveBlocks=0
transmitBlocks=0
cellDelin=0
linkRetrain=0
initErrors=0
initTimeouts=0
lossOfFraming=0
erroredSecs=0
FECErrors=0
ATUCFECErrors=0
HECErrors=73044
ATUCHECErrors=723
CRCErrors=7419
ATUCCRCErrors=528
[error]0
Jon
13-10-2014 10:57 AM
An answer is required on the 9dB SNRM from CRT. Is this the target in spite of a request to set to 6dB or is this line speed banded?
Kevin
13-10-2014 11:32 AM
hopefully we will get an answer on this soon.
Jon
13-10-2014 8:07 PM
13-10-2014 8:35 PM
13-10-2014 8:56 PM
there is the possibility that in fact you synced when there was some noise around and if it's now less noise, the actual margin will have increased.
IIRC, without reading your thread again, you get periodic burst of noise at certain times of day? If so, avoiding those time slots, I'd try a resync in daylight tomorrow, but as the line is in training (I guess) still, I would do so by clicking Disconnect to drop your PPP Internet session (if you can on this modem/router) and then power off for an hour minimum. Power on when you can avoid any noisy time slots. Don't forget to login and click Connect if you did a Disconnect. See if you end up with 6dB SNRM at that time. Otherwise someone from CRT may need to look at the settings for you.
13-10-2014 9:01 PM
