Lower speed under Plusnet?
- Lower speed under Plusnet?
17-10-2011 12:18 PM
i can not see the stats on BT sppedtester as I have said in another thread that my number is no longer recognised by BT on that speed test site
Re: Lower speed under Plusnet?
17-10-2011 12:37 PM
There's lots of errors on the line at the moment, can you try plugging into the test socket?
Jojo
17-10-2011 3:57 PM
Test socket...you will have to explain to me where I can find that Jo have I one on the router or the BT ADSL V10 socket?
jim:quote
17-10-2011 4:03 PM
17-10-2011 4:24 PM
Quote from: Oldjim You would remove the lower half - which in your case is the bit with the filter included and use an external filter
Cheers Jim, did that, not sure what the next step was to be or what it proves but nothing is any better or worse.
17-10-2011 4:29 PM
If you post the full stats from the router tomorrow we should have an idea if things have improved
17-10-2011 4:43 PM
As you have guessed by now I am not too well up on the technical side but have a basic knowledge of how it all works, now where is a link explaining how I find the stats from the router
jim:quote
17-10-2011 4:44 PM
17-10-2011 4:49 PM
jim:quote
17-10-2011 6:56 PM
19-10-2011 6:05 PM
In the meantime I can confirm that the speed did improve and were showing as 3 meg plus but currently under 3 but a lot better than under 2 meg so hoping it stays above that.
Uptime: 0 days, 0:44:44
DSL Type: G.992.1 annex A
Channel mode: Fast
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,028 / 4,032
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,032
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 12.14
Output Power (Up/Down) [dBm]: 12.0 / 19.0
Line Attenuation (Up/Down) [dB]: 26.5 / 51.0
SN Margin (Up/Down) [dB]: 23.0 / 7.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 41 / 0
Loss of Signal (Local/Remote): 327,678 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 2 / 0
FEC Errors (Up/Down): 11 / 0
CRC Errors (Up/Down): 16 / 7,526
HEC Errors (Up/Down): 0 / 8,305
