Low sync speed
- Low sync speed
Low sync speed
31-08-2009 7:21 PM
Getting 1600 download sync with a noise margin of over 15db. What the hell?
Message 1 of 4
(892 Views)
3 REPLIES 3
Re: Low sync speed
31-08-2009 7:52 PM
... and now no dial tone too. Tried replacing all filters and plugging directly into the wall still no joy. Feckin thing
Message 2 of 4
(495 Views)
Re: Low sync speed
31-08-2009 7:55 PM
The BT automatic systems have decided that your line is unstable at lower noise margins and so have increased the default noise margin from 6dB to 15dB
If you would like some help on improving it can you please post the stats from your router - noise margin, attenuation and speeds.
Also are you plugged into the master socket or a diffeent one
Once you have posted those we can take the investigation to the next stage
Edit - first thing is to check if you have a dial tone with only the phone connected. If you don't then report a voice fault to your phone supplier (not necessarily the same as the broadband supplier) without mentioning broadband
Message 3 of 4
(495 Views)
Re: Low sync speed
31-08-2009 9:22 PM
Message 4 of 4
(495 Views)
