Low attenuation but high SNR, can speed be improved?
- Low attenuation but high SNR, can speed be improve...
- « Previous
- 1
- 2
- Next »
Re: Low attenuation but high SNR, can speed be improved?
22-08-2011 1:06 PM
Should be live in the next couple of hours. Any issues let us know.
22-08-2011 2:20 PM
23-08-2011 12:13 PM
Checked last night and the upload speed has increased, so thanks for sorting this. It unfortunately only achieves upload speeds of ~750kbps, whereas previously would achieve closer to 1mbps. Download speed though continues to increase and on speedtest, i now get over 11mbps.
Unfortunately wasn't able to get a reliable btspeedtester one last night, will try again tonight.
Also i noticed my ping times have increased since reducing the SNR. They have gone from ~20ms to ~40ms. Having done tests at pingtest, there appears to be packet loss of 1-2%, the site recommends investigating any loss higher than 0% as this will impact online gaming, i wanted to improve my experience for gaming, which i why i persude this. Do you know what may be causing this?
Are the two things (higer ping, lower upload) likely to be related. If so do you know what can be done to fix this? Would turning off interleaving improve things, i think i had it turned on previously though?
Cheers.
23-08-2011 12:17 PM
If you would like us to remove interleaving then please let us know.
23-08-2011 12:26 PM
The changes usually take 24 hours to take effect.
23-08-2011 1:56 PM
Please go ahead and turn interleaving off as i would appreciate the higher upload and lower ping.
Cheers.
23-08-2011 4:43 PM
How long does the interleaving off request take as i'm keen to get some improved black ops playing done tonight?, if you can get it done that fast.
Thanks for your help so far, all has been going great thanks to you.
23-08-2011 5:21 PM
I'm sorry but i've been waiting all afternoon to get through to the department that can adjust your line. Unfortunately it looks like it's not going to be possible before 5:30. I will contact the team first thing tomorrow morning and have the line adjusted for you.
Edit: Just as I finished typing this post the team responded!
The profile change has been requested and you should see this live within the next few hours.
23-08-2011 5:53 PM
23-08-2011 6:03 PM
Looks great, will upload a btspeedtester one later on.
EDIT: Here is test from plusnet speedtester:
EDIT2: Get some very strange results from btspeedtester though on the download speed, had results of 3mbps and 5mbps, could this be due to the line training, or is this the stability issues you mentioned? I assumed stability affected whether the line disconnects rather than speed fluctuations, which i would term more as volatility.
24-08-2011 12:46 PM
24-08-2011 2:52 PM
Had a great night on black ops last night btw, k/d always above 1. My best was 17 kills to 3 deaths. I put it down to the connection as i normally don't get those type of results.
25-08-2011 1:17 PM
Oh, and... duck
25-08-2011 1:32 PM
Quote from: Mathias My best was 17 kills to 3 deaths...
Mine is usually the other way round
- « Previous
- 1
- 2
- Next »
