Low Speed
- Low Speed
Low Speed
16-10-2012 1:48 PM
I've noticed my download speed getting pretty slow lateley, so checked my speed at https://portal.plus.net/my.html?action=data_transfer_speed.
It seems to be set at 2Mb. I did the BT speedtest and am getting around 1850kbps. My router says DownStream Connection Speed 4768 kbps.
I raised a ticket on this on Saturday, but have had no response. I did all the troubleshooter things, rebooted router, changed filters, unplugged all other equipment. I can't plug into the mastersocket, I don't have one.
I don't know anything about how all this stuff works, but I'm sure I got faster speeds than this in the past.
Can anybody advise?
Can anybody advise?
Message 1 of 9
(1,282 Views)
8 REPLIES 8
Re: Low Speed
16-10-2012 1:55 PM
When you did the BT speedtest what was the reported IP profile - you would need to run the diagnostic version for this
Message 2 of 9
(741 Views)
Re: Low Speed
16-10-2012 1:58 PM
Just this minute had a text from support saying there was a restriction on my line and they have issued a manual order for it to be removed.
Hopefully things will be better soon.
Thanks.
Thanks.
Message 3 of 9
(741 Views)
Re: Low Speed
16-10-2012 2:32 PM
Glad that's sorted for you, if you have any issues please let me know.
Message 4 of 9
(741 Views)
Re: Low Speed
17-10-2012 9:59 AM
My line speed seems still to be at 2Mb. Does this mean my speed restriction hasn't been removed yet? It was supposed to happen within 4 hours.
Message 5 of 9
(741 Views)
Re: Low Speed
17-10-2012 10:33 AM
It is still showing as banded, I've replaced the SNR reset for you, I'll check back later this afternoon to see if it has completed.
It usually does take around 4 hours but can in some instances take 24 hours.
Message 6 of 9
(741 Views)
Re: Low Speed
17-10-2012 4:04 PM
Is there any news on this? It seems still to be at 2MB.
Message 7 of 9
(741 Views)
Re: Low Speed
17-10-2012 4:05 PM
Yep the banding has been removed, as I mentioned it can take up-to 24 hours, although I would have hoped that you will see an improvement before then, so hopefully tonight.
Message 8 of 9
(741 Views)
Re: Low Speed
17-10-2012 8:00 PM
What's your Current Line speed (Login required) showing as?
This should match the BT IP profile.
And you didn't respond to Jim's question.
Are you on a 20CN or 21CN connection? If you don't know, copy and paste the full results of a BT Diagnostic speed test.
Also check the VP status of your Exchange here
Message 9 of 9
(741 Views)
