Loss of internet
- Loss of internet
- « Previous
- 1
- 2
- Next »
Re: Loss of internet
10-09-2012 5:32 PM
Is it connected via a filter or is it directly connected? If it's not filtered it will be causing issues.
Message 16 of 18
(213 Views)
10-09-2012 5:55 PM
Without looking jelv, its not easy to get at its connections I believe it was delivered with a filter, which I would have used if it was there. But I will check (later) Because of its position it is used on a long extension for the phone line.
Message 17 of 18
(213 Views)
11-09-2012 5:48 PM
I had a Netgear wireless router N150.
It was forever dropping the internet connection.
Upwards of 5 times a day.
I now have a TP LINK TD-W8960N
which I bought on Amazon about 6 months ago.
It has not dropped the Internet connection once.
I did not change anything other than the Router.
So if you have checked out all the other things previous
contributors have talked about and there is still no joy,
buy a TP LINK wireless router.
Good luck.
OrchidC
Message 18 of 18
(213 Views)
- « Previous
- 1
- 2
- Next »
