Line fault supplemental information.
- Line fault supplemental information.
20-06-2013 8:15 AM
Hi guys, I submitted a line fault at faults.plus.net earlier this morning.
Checking a few other things to see what supplemental information I can give you, noticed the error rates on the router are through the roof.
Router was rebooted 12 hours ago..
FEC: 0 0
CRC: 22064 0
ES: 1571 1115
SES: 511 105
UAS: 8898 8927
LOS: 34 0
LOF: 305 0
Noticed random interval disconnects starting somewhere between 18:30 and 19:00 last night. Seemed to happen under higher load, which makes sense as the error rate probably increased. Had perfect speeds and very little dropouts in the previous 4 months or so.
No major service issues reported for the exchange (Leicester Central)
FEC: 0 0
CRC: 22064 0
ES: 1571 1115
SES: 511 105
UAS: 8898 8927
LOS: 34 0
LOF: 305 0
Message 1 of 3
(662 Views)
2 REPLIES 2
Re: Line fault supplemental information.
20-06-2013 11:24 AM
Definitely dropping:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13717238293876.png"/>
You've done the right thing in raising a fault, our team will be back to you with test results soon.
Message 2 of 3
(378 Views)
20-06-2013 11:58 AM
FYI, the gaps of no session are where I physically disconnected the router. The disconnects were so rapid I didn't want to risk DLM nuking me to oblivion, so I pulled the plug hoping it was a temporary issue that would be resolved in the mean time.
Message 3 of 3
(378 Views)
