Just moved back to the 20CN connection
- Just moved back to the 20CN connection
26-05-2010 2:12 PM
I suspect I will have to let my line re-train, but should I be worried that in the 1st 2 hours of connection after BT have put me back on the 20CN network my router has racked up 45,000 CRC errors ? Apart from the constant line resets and wildly variable speeds I was only getting a few hundred - if that before ?
Dave
Dave
Message 1 of 3
(791 Views)
2 REPLIES 2
Re: Just moved back to the 20CN connection
26-05-2010 2:45 PM
Maybe it's something to do with Interleaving - I used to have that before - not sure what any of this stuff really means.
> adsl status
--------------------------- ATU-R Info (hw: annex A, f/w: annex A) -----------
Running Mode : G.DMT State : SHOWTIME
DS Actual Rate : 2848000 bps US Actual Rate : 448000 bps
DS Attainable Rate : 2848000 bps US Attainable Rate : 944000 bps
DS Path Mode : Fast US Path Mode : Fast
DS Interleave Depth : 1 US Interleave Depth : 1
NE Current Attenuation : 60 dB Cur SNR Margin : 6 dB
DS actual PSD : 18. 2 dB US actual PSD : 12. 4 dB
ADSL Firmware Version : 232201_A
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 31 dB Far SNR Margin : 19 dB
CO ITU Version[0] : 00005453 CO ITU Version[1] : 00005443
DSLAM CHIPSET VENDOR : < TI >
> adsl show
DOWNSTREAM :
Bin SNR Gain Bi - Bin SNR Gain Bi - Bin SNR Gain Bi - Bin SNR Gain Bi
dB dB ts dB dB ts dB dB ts dB dB ts
0 0 0 0 * 1 0 0 0 * 2 0 0 0 * 3 0 0 0
4 0 0 0 * 5 0 0 0 * 6 0 0 0 * 7 0 0 0
8 0 0 0 * 9 0 0 0 * 10 0 0 0 * 11 0 0 0
12 0 0 0 * 13 0 0 0 * 14 0 0 0 * 15 0 0 0
16 0 0 0 * 17 0 0 0 * 18 0 0 0 * 19 0 0 0
20 0 0 0 * 21 0 0 0 * 22 0 0 0 * 23 0 0 0
24 0 0 0 * 25 0 0 0 * 26 0 0 0 * 27 0 0 0
28 0 0 0 * 29 0 0 0 * 30 0 0 0 * 31 0 0 0
32 0 0 0 * 33 0 0 0 * 34 0 0 0 * 35 0 0 5
36 0 0 6 * 37 0 0 7 * 38 0 0 8 * 39 0 0 8
40 0 0 9 * 41 0 0 10 * 42 0 0 10 * 43 0 0 10
44 0 0 11 * 45 0 0 11 * 46 0 0 11 * 47 0 0 11
48 0 0 11 * 49 0 0 11 * 50 0 0 11 * 51 0 0 11
52 0 0 11 * 53 0 0 11 * 54 0 0 11 * 55 0 0 11
56 0 0 11 * 57 0 0 11 * 58 0 0 11 * 59 0 0 11
60 0 0 11 * 61 0 0 11 * 62 0 0 11 * 63 0 0 10
64 0 0 0 * 65 0 0 10 * 66 0 0 10 * 67 0 0 10
68 0 0 10 * 69 0 0 10 * 70 0 0 10 * 71 0 0 10
72 0 0 9 * 73 0 0 9 * 74 0 0 9 * 75 0 0 9
76 0 0 9 * 77 0 0 9 * 78 0 0 9 * 79 0 0 9
80 0 0 8 * 81 0 0 8 * 82 0 0 8 * 83 0 0 8
84 0 0 8 * 85 0 0 8 * 86 0 0 8 * 87 0 0 8
88 0 0 8 * 89 0 0 8 * 90 0 0 8 * 91 0 0 8
92 0 0 8 * 93 0 0 8 * 94 0 0 7 * 95 0 0 7
96 0 0 7 * 97 0 0 7 * 98 0 0 7 * 99 0 0 7
100 0 0 7 * 101 0 0 7 * 102 0 0 7 * 103 0 0 6
104 0 0 6 * 105 0 0 6 * 106 0 0 6 * 107 0 0 6
108 0 0 6 * 109 0 0 5 * 110 0 0 5 * 111 0 0 5
112 0 0 5 * 113 0 0 2 * 114 0 0 5 * 115 0 0 5
116 0 0 5 * 117 0 0 5 * 118 0 0 5 * 119 0 0 5
120 0 0 5 * 121 0 0 4 * 122 0 0 5 * 123 0 0 4
124 0 0 4 * 125 0 0 4 * 126 0 0 4 * 127 0 0 4
128 0 0 4 * 129 0 0 2 * 130 0 0 2 * 131 0 0 3
132 0 0 4 * 133 0 0 4 * 134 0 0 4 * 135 0 0 4
136 0 0 3 * 137 0 0 3 * 138 0 0 3 * 139 0 0 3
140 0 0 0 * 141 0 0 2 * 142 0 0 2 * 143 0 0 2
144 0 0 0 * 145 0 0 0 * 146 0 0 0 * 147 0 0 0
148 0 0 2 * 149 0 0 0 * 150 0 0 0 * 151 0 0 0
152 0 0 0 * 153 0 0 0 * 154 0 0 0 * 155 0 0 0
156 0 0 0 * 157 0 0 0 * 158 0 0 0 * 159 0 0 0
160 0 0 0 * 161 0 0 0 * 162 0 0 0 * 163 0 0 0
164 0 0 0 * 165 0 0 0 * 166 0 0 0 * 167 0 0 0
168 0 0 0 * 169 0 0 0 * 170 0 0 0 * 171 0 0 0
172 0 0 0 * 173 0 0 0 * 174 0 0 0 * 175 0 0 0
176 0 0 0 * 177 0 0 0 * 178 0 0 0 * 179 0 0 0
180 0 0 0 * 181 0 0 0 * 182 0 0 0 * 183 0 0 0
184 0 0 0 * 185 0 0 0 * 186 0 0 0 * 187 0 0 0
188 0 0 0 * 189 0 0 0 * 190 0 0 0 * 191 0 0 0
192 0 0 0 * 193 0 0 0 * 194 0 0 0 * 195 0 0 0
196 0 0 0 * 197 0 0 0 * 198 0 0 0 * 199 0 0 0
200 0 0 0 * 201 0 0 0 * 202 0 0 0 * 203 0 0 0
204 0 0 0 * 205 0 0 0 * 206 0 0 0 * 207 0 0 0
208 0 0 0 * 209 0 0 0 * 210 0 0 0 * 211 0 0 0
212 0 0 0 * 213 0 0 0 * 214 0 0 0 * 215 0 0 0
216 0 0 0 * 217 0 0 0 * 218 0 0 0 * 219 0 0 0
220 0 0 0 * 221 0 0 0 * 222 0 0 0 * 223 0 0 0
224 0 0 0 * 225 0 0 0 * 226 0 0 0 * 227 0 0 0
228 0 0 0 * 229 0 0 0 * 230 0 0 0 * 231 0 0 0
232 0 0 0 * 233 0 0 0 * 234 0 0 0 * 235 0 0 0
236 0 0 0 * 237 0 0 0 * 238 0 0 0 * 239 0 0 0
240 0 0 0 * 241 0 0 0 * 242 0 0 0 * 243 0 0 0
244 0 0 0 * 245 0 0 0 * 246 0 0 0 * 247 0 0 0
248 0 0 0 * 249 0 0 0 * 250 0 0 0 * 251 0 0 0
252 0 0 0 * 253 0 0 0 * 254 0 0 0 * 255 0 0 0
> adsl status
> adsl show
DOWNSTREAM :
Message 2 of 3
(369 Views)
26-05-2010 4:54 PM
'Interleave depth 1' translates as 'No Interleaving'. Therefore no Forward Error Correction (FEC), and so higher CRC errors. I'd guess a 10 day training period has started?
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 3 of 3
(369 Views)
