Is the TG582n Router compatible with the Edimax EW7717-UN USB wireless adaptor?
- Is the TG582n Router compatible with the Edimax EW...
21-09-2012 4:51 PM
I have had my existing (Plusnet-supplied) Thomson 585v7 router for two and a quarter years now and although it still works ok it is only wireless-g and I sometimes have signal strength issues although not so bad as to be problematic. However, the fact is that I am heavily reliant on my home broadband connection and as I don't currently have a spare router I thought it might be a good idea to order the current Plusnet offering and keep the Thomson as a spare.
I don't have a wireless card on my current PC but have used an Edimax EW7717-UN USB adaptor since it was recommended to me in November 2010 by Oldjim (thanks again ). So all I need to know is if the Technicolor TG582n and the Edimax EW7717-UN are compatible?
Message 1 of 3
(4,203 Views)
2 REPLIES 2
Re: Is the TG582n Router compatible with the Edimax EW7717-UN USB wireless adaptor?
21-09-2012 5:02 PM
Hi there
Yes that should work fine.
Regards
Mike
Regards
Mike
Message 2 of 3
(384 Views)
21-09-2012 5:04 PM
Great!
Thanks for the quick reply, Mike.
[PS: New router ordered. ]
Message 3 of 3
(384 Views)
