Intermittent Slow Speeds, Not Sure?
- Intermittent Slow Speeds, Not Sure?
12-09-2012 3:16 PM
Most sites I visit load fine. But, some do not. I've been growling at my hosting provider, but again, not so sure now. Can someone please tell me if this looks normal:
1 99 ms 26 ms 98 ms router [xxx.xxx.x.xx]
2 130 ms 157 ms 274 ms lo0-central10.pcl-ag01.plus.net [195.166.128.182]
3 12 ms 12 ms 31 ms link10-central10.pcl-gw02.plus.net [84.93.249.18]
4 11 ms 12 ms 11 ms xe-0-2-0.pcl-cr02.plus.net [212.159.1.2]
5 12 ms 44 ms 32 ms ae1.ptw-cr02.plus.net [195.166.129.2]
6 33 ms 12 ms 12 ms ae2.ptw-cr01.plus.net [195.166.129.4]
7 11 ms 12 ms 13 ms Ge-0-1.linx.lon.nodefour.net [195.66.224.135]
8 11 ms 12 ms 12 ms 83.166.164.85
9 13 ms 12 ms 12 ms mx01-xe2.0.0-lon.gs.nodefour.net [83.166.164.34]
10 15 ms 15 ms 16 ms mx02-xe1.2.0-dry.dc2.nodefour.net [83.166.164.38]
11 15 ms 20 ms 21 ms 83.166.164.54
12 15 ms 14 ms 14 ms
Trace complete.
Hope that's enough info. If you need more, please, let me know and I'll do my best to provide it.
Many thanks.
Trace complete.
Many thanks.
Message 1 of 4
(823 Views)
3 REPLIES 3
Re: Intermittent Slow Speeds, Not Sure?
13-09-2012 1:34 PM
This trace route looks fine, the second hop to our gateway does have a higher ping but this should not cause any performance issues.
How many other sites do you have this issue with? can you provide the trace route for them?
Message 2 of 4
(356 Views)
13-09-2012 4:06 PM
Here you go:
tracert www.google.co.uk
Tracing route to www.google.co.uk [173.194.78.94] over a maximum of 30 hops:
1 50 ms 98 ms 99 ms router [192.168.1.10]
2 13 ms 20 ms 12 ms lo0-central10.pcl-ag01.plus.net [195.166.128.182]
3 22 ms 14 ms 210 ms link8-central10.pcl-gw02.plus.net [84.93.249.14]
4 30 ms 12 ms 11 ms xe-0-2-0.pcl-cr02.plus.net [212.159.1.2]
5 11 ms 12 ms 13 ms ae1.ptw-cr02.plus.net [195.166.129.2]
6 12 ms 12 ms 12 ms 72.14.223.32
7 12 ms 13 ms 12 ms 209.85.252.186
8 13 ms 12 ms 13 ms 209.85.253.94
9 17 ms 18 ms 21 ms 66.249.95.173
10 17 ms 19 ms 18 ms 72.14.236.191
11 * * * Request timed out.
12 17 ms 16 ms 17 ms wg-in-f94.1e100.net [173.194.78.94]
Trace complete.
Sometimes my IP doesn't change for weeks. I'll check and may reboot my router. Forgot, that may have cleared this type of issue up, previously. So weird. Some sites are quick, some are slow. So hard to tell.
Thanks Chris. Please do let me know if you have any other theories/solutions etc.
Trace complete.
Message 3 of 4
(356 Views)
17-09-2012 9:49 AM
Everything again looks fine on your trace route. It will be a case of when you are experiencing any issues, run a trace route so we can try and pin-point where the issue is.
Message 4 of 4
(356 Views)
