Interleaving
- Interleaving
Interleaving
22-11-2009 12:51 PM
Just seen the new button under connection settings about interleaving.
So if its switches off and the connection becomes unstable will i not be able to turn it back on? Even if i paid for it to be put back on?
Glenn.
Glenn.
Message 1 of 6
(1,116 Views)
5 REPLIES 5
Re: Interleaving
22-11-2009 1:10 PM
its free to turn it on and off.
each request takes about 1 working day for bt to do
all that button does is raise a ticket on your account for comms to pick up and action
Message 2 of 6
(472 Views)
Re: Interleaving
22-11-2009 8:28 PM
Is it best waiting after the 10 day starting period before i turn it off? But i will definalty be turning it off as soon as i can.
Glenn.
Glenn.
Message 3 of 6
(472 Views)
Re: Interleaving
22-11-2009 9:29 PM
Probably, depends on your current stats.
Message 4 of 6
(472 Views)
Re: Interleaving
22-11-2009 11:21 PM
Can you tell me please, why BT would turn off interleaving, as per ticket ID: 30876197?
I'm experiencing falling d/load speeds now @ 9/800 kbps. IP Profile for line is now 3000 kbps
Many thanks
Ian
Many thanks
Ian
Message 5 of 6
(472 Views)
Re:Interleaving
24-11-2009 11:40 AM
Hi exporters,
I've just had a look on BTs systems and it's showing that interleaving is on at the moment. Did you want it removing? It's best on if you've a long line as it'll help keep the connection stable, but you will get faster pings without it.
Message 6 of 6
(472 Views)
