Installed New Router to help with Speed and Stabilty
- Installed New Router to help with Speed and Stabil...
- « Previous
- 1
- 2
- Next »
Re: Installed New Router to help with Speed and Stabilty
08-10-2009 11:45 AM
08-10-2009 12:32 PM
{root}=>:adsl info expand=enabled
Modemstate : Up
xDSL Type : ADSL
xDSL Standard : ITU-T G.992.1
xDSL Annex : Annex A
Channel Mode : Interleaved
Uptime (days hh:mm:ss) : 3 days, 5:47:20
(rest snipped)
If it's not as obvious on your 585 then let me know what version of firmware your router is running and I'll load it up on one I have here and see if I can find it (unless anyone else comes up with the answer first )
08-10-2009 1:57 PM
Product Name: TG585 v7
Software Release: 7.4.4.7
When I run adsl info expand=enabled
I get the below plus a lot me but no mention of interleaved or Fast
Modemstate : Up
xDSL Type : ADSL2
xDSL Standard : ITU-T G.992.3
Uptime (days hh:mm:ss) : 0 days, 9:20:31
08-10-2009 2:44 PM
09-10-2009 8:34 AM
I had a few problems last night with the router, between about 6:30 and 9:00 the router would just not stay up, every time it went down it took the wireless down with it also. I eventually powered the router off for 5 minutes and then back on and it worked ok.
09-10-2009 9:48 AM
Yeah - Looking at your connections logs, things looked pretty rubbish from about 6-9pm.
However, the connection has been up ever since. I'm trying to get a line test run on your connection, but it's taking an absolute age.
09-10-2009 11:38 AM
I have noticed a little more noise low pitch hiss on the voice also today, not a great deal but it is noticable.
09-10-2009 11:46 AM
09-10-2009 3:24 PM
11-10-2009 7:54 PM
The new router has needed rebooting twice this weekend, as it just seemed to lock up, not broadcasting any wireless, and not responding to a physical LAN connection. It seems that if the ADSL goes down every time it restarts the router, and sometimes needs a full reboot to recover.
To be honest I am not seeing any/much benefit of this router over my Netgear DG834GT. This seems to lockup completly and need a reboot to get back up and the netgear, seems to get a higher sync but then seems to loose framing or service, even though the SNR is still high. It is getting to the point that my Mobile Broadband connection is more stable and quicker than this. I just dont know where to go from here, I cannot help but think it is a problem in the exchange on the broadband side, it was fast and stable when running on LLU and I have only had these problems since moving off LLU.
Does anyone know if LLU is more suited to longer lines over standard BT based ADSL.
Would capping the upstream sync improve the downstream speed and general stability.
12-10-2009 1:04 PM
I'm happy to try if you would like me to do so.
- « Previous
- 1
- 2
- Next »
