Installed New Router to help with Speed and Stabilty
- Installed New Router to help with Speed and Stabil...
01-10-2009 1:33 PM
Is there anything I can do to get the speed up to a reasonable level, or will I just have to wait.
Should the training period be restarted now the new router is in place.
Re: Installed New Router to help with Speed and Stabilty
01-10-2009 1:39 PM
if the old router was causing sync problems the dlm may take a few days to feel comftable with the new router before trying new noise margins and removing banding ect
01-10-2009 1:54 PM
Was getting below with old router:
Noise Margin: 23.7 dB
Connection Rate: 1159 Kbps
Line Attenuation: 58.0 dB
Power: 0.0 dBm
Max Rate: 2480 Kbps
SF: 2653351
SF Errors: 0
Reed Solomon: 43116960
RS Corrected: 274
RS Un-Corrected: 0
HEC: 0
Errored Seconds: 761
Severe ES: 680
Interleave Depth: 8
Bitswaps: 169
UpStream
Noise Margin: 4.9 dB
Connection Rate: 721 Kbps
Line Attenuation: 36.3 dB
Power: 12.9 dBm
Max Rate: 708 Kbps
SF: 2381512
SF Errors: 2
Reed Solomon: 3961915
RS Corrected: 60
RS Un-Corrected: 0
HEC: 2
Errored Seconds: 2
Severe ES: 0
Interleave Depth: 2
Bitswaps: 2
Getting below now with new router:
Uptime: 0 days, 0:02:13
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 776 / 2,944
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 34.5 / 57.0
SN Margin (Up/Down) [dB]: 5.5 / 6.5
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 0 / 2,227
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
I will have to see how things go, not quite the 3500+ I was getting before on LLU but, its getting closer.
I had a ticket outstatinging on joining the Trial, I informed them this morning that the new Router has been installed and BT have now started the 10 day Training period again, fingers crossed.
01-10-2009 8:56 PM
06-10-2009 3:05 PM
Quote from: amjrobson ............................
Should be G.992.5 shouldn't it?
06-10-2009 4:32 PM
The DLM will allways sync on adsl2 (G.992.3) and not adsl2+(G.992.5) if none of the adsl2+ tones are not useable
06-10-2009 7:34 PM
My sync speed has slowly dropped down from just under 3000 to 1200 again. Perhaps I need to get BT out after all, the rerun of the training period is up on Monday so if things do not improve I will be requestign BT to come out and take a look. Going from a stable 3500 down stream connection to 1200 just is not on.
Router Stats now
Uptime: 0 days, 20:27:58
Bandwidth (Up/Down) [kbps/kbps]: 831 / 1,248
Line Attenuation (Up/Down) [dB]: 34.5 / 58.5
SN Margin (Up/Down) [dB]: 5.5 / 15.5
07-10-2009 8:48 AM
Quote from: ASBO Not at 57db atten no.
I was not aware of that. (In a Wayne's World style)
Thank you.
07-10-2009 9:27 AM
It's not a banded profile, which was my first supicion when I saw the noise margin being over 15dB. The lines not interleaved though, which could help.
Mind if I turn it on?
07-10-2009 11:13 AM
Yes by all means turn interleaving on.
Cheers
07-10-2009 1:49 PM
Cheers,
07-10-2009 2:18 PM
08-10-2009 10:41 AM
Is it possible to see on the Speedtouch 585 routers is the line is running a Fast or Interleaved path, I have not seen any change yet.
08-10-2009 11:03 AM
08-10-2009 11:38 AM
Quote from: amjrobson Is it possible to see on the Speedtouch 585 routers is the line is running a Fast or Interleaved path,
Depending on the router firmware version one of the following entered at the command line should give you the current channel mode.
:adsl info expand=enabled
or
:xdsl info expand=enabled
