Increase in Noise Margin
- Increase in Noise Margin
11-09-2009 10:23 AM
Any ideas as to why this should happen? I am waiting to be put on the ADSL2+ trial but haven’t heard that this has commenced
Absolutely nothing within the house has changed
ADSL Link Downstream Upstream
Connection Speed 4800 kbps 448 kbps
Line Attenuation 47 db 13.5 db
Noise Margin 12 db 23 db
Any thoughts would be appreciated
Re: Increase in Noise Margin
11-09-2009 10:26 AM
It should be reset when you're moved onto ADSL2+ so I don't think you'll have to wait a massively long period of time for it to be reset.
However, worth checking your line to make sure there's no audible noise present. It shouldn't happen for no reason!
11-09-2009 10:32 AM
Phone line sounds crystal clear, no different from any other day. I just don’t get it how a rock solid connection speed of over 6mb can drop so suddenly without (apparently) anything changing. I know that bad weather can affect things but it is a pleasant, warm, bright day.
Rob
11-09-2009 10:36 AM
Your Community login is still linked to your Metronet account
11-09-2009 10:42 AM
11-09-2009 11:12 AM
As I mentioned, it looks like it was caused by a blip in the early hours. Hopefully it should return to normal in the not to distant future.
14-09-2009 8:54 AM
Connection Speed 4512 kbps 448 kbps
My rock solid connection of about 6.5mb has lost 2mb despite no changes from my end at all. I'm quite concerned as to how this can happen and would appreciate your advice to return my conncetion speed back to previous levels.
Rob
14-09-2009 9:44 AM
I've mentioned elsewhere, that we're going to be joining a pilot scheme allowing us to reset the noise margin via the use of a button, but that's not until November.
You can raise a fault asking for the noise margin to be changed, but BT are becoming increasingly unwilling to make such changes.
14-09-2009 10:02 AM
Would you advice then be just to sit back and allow the automation to reset the noise margin at some point within the 28 day period? I’m due to go on the ADSL+2 trial very soon, how will this noise margin increase be affected?
Rob
14-09-2009 10:17 AM
It's easier that way
14-09-2009 12:20 PM
Quote from: Jameseh ... a pilot scheme allowing us to reset the noise margin via the use of a button, but that's not until November.
Is this new button for both IPStreamMax and IPStreamConnect connections?
Finally the first admission from BTW that DLM may not be completely cognizant of what it is doing.
SW.
3Mb FTTC
14-09-2009 1:04 PM
I'd suggest it to be offered on WBC/WBMC/IPSC if the trial is successful.
15-09-2009 7:50 AM
3Mb FTTC
15-09-2009 8:56 AM
15-09-2009 9:36 PM
surely PN is moving over to IPSC as soon as possible as it is cheaper, and BTW say they are all ready to go ... and I would not doubt BTW in anything they say at all!
SW.
3Mb FTTC
