Incorrect traffic managment - wireshark
- Incorrect traffic managment - wireshark
10-11-2008 5:59 PM
I have seen a post regarding wireshark and incorrect prioritised traffic .
I'm on the pro package 19.99 ( for gaming )and wireshark shows a hex value of 0x80 for interactive traffic , is this correct ? seeing on the video tutorial for gaming and VOIP it should be another value
Message 1 of 3
(867 Views)
2 REPLIES 2
Re: Incorrect traffic managment - wireshark
10-11-2008 7:06 PM
Depends on the game.
http://www.plus.net/support/broadband/troubleshooting/wireshark.shtml
0x80 is the value for Gold traffic. For all traffic on your package you should see 0x80 or 0xa0 (Titanium).
Which game is it and do you know if you are using standard ports or server specific modifications?
This will help to see if what changes we may need to make.
Message 2 of 3
(310 Views)
10-11-2008 7:14 PM
The game is Quakeworld , no mods , just all servers run on port ranges from 27500 to 28000+ normaly up 28005 depending (standard ports) .
But it seem the same on warsow and quake2 (27500 +) + 3 (27950 +) + 4 )27000 +
Message 3 of 3
(310 Views)
