IP profile reset problem
- IP profile reset problem
07-05-2010 11:25 PM
mybroadbandspeed showed 467 down / 691 up
No change in sync (been synced for a week or more since last router reset at 7616000)
snr etc normal for my line
but did have several drops today in connection to PN (nb not resyncs)
ended up on pcl-ag03.
will hop tomorrow morning but wondered if there was a known problem tonight?
EDIT: Changed Subject to correctly reflect problem
Re: Speed problem 7th May 2010
08-05-2010 8:14 AM
Performance poor again this morning (8th May), similar speedtests to yesterday evening, so will try a gateway hop now .
08-05-2010 8:48 AM
It makes broadband pretty unusable for me .
Plus I'd like to know why it's happened?
08-05-2010 9:25 AM
In fact it's been running continuously (and synced at 7616000) for nearly 10 days now, and I'm pretty sure the connection drops have been exchange initiated.
When I asked why my profile could not be changed manually, I was told this would "damage my line" because my equipment would receive unnecessary frequencies.
hmmm
PS exchange is showing green all the way
08-05-2010 10:18 AM
Quote When I asked why my profile could not be changed manually, I was told this would "damage my line" because my equipment would receive unnecessary frequencies.
So changing PN's line profile would some how build a sub station close to your line and introduce some nasty unnecessary frequencies.
Sounds like you monitor your line OK and know its just the pppo session thats being dropping, so what are your line profiles on bt's and pn's systems? if the cs agent was knowledgeable and correct in what they said, your bt profile should be set very low at like 500kbps
08-05-2010 10:46 AM
I'll follow the testing protocols as CSC request to make sure, but after 5 years of almost absolute stability on this line, and with no changes to equipment within the property at all, I'm inclined to think it's in the copper or at the exchange; Unless of course I have a microfilter going bad or my router is giving up, but the latter is a DrayTek 2800VG and they tend to just go on and on (which is why I bought it)
08-05-2010 10:52 AM
Re: IP profile reset problem
08-05-2010 10:59 AM
11-05-2010 6:55 PM
speedtests etc still very slow -- do I need to restart ppoa or do i have to reboot the router?
12-05-2010 10:25 AM
12-05-2010 6:42 PM
