IP address for Plusnet
- IP address for Plusnet
10-10-2015 2:02 PM
Hello , on Windows 10 my PC crashed .recovered most of MS settings but on ethernet limited connection . Need IP address. can some learned user help with Internet Options configuration inc. Homepage internet address ,LAN settings also Network Connection page . Have signal on my lap-top and No2 PC .. Tried " ipconfig/release " no go . Also off topic , both firewalls have probs for me to solve before going online .Bullguard did not detect AV or malware . Any ideas from you bright people out there ? Thanks R
Message 1 of 2
(954 Views)
1 REPLY 1
Re: IP address for Plusnet
10-10-2015 3:48 PM
Hi Corsairxf4u,
A warm welcome to the forums. Given what you have written, I suggest that the thread's title is somewhat misleading - you do not need an IP address for PlusNet, rather you need to know how to sort out your PC connectivity.
Would I be correct that reference to "Ethernet limited connection" is from the PC's network connection status?
Is the PC connected to the router using a cable or is it wifi?
Can you do run ipconfig /all and report the values highlighted below...
If it shows DHCP is enabled and there is not a 192.168.x.x address then that suggests a problem with the router or your connection to it.
If you are using a PlusNet router, then which one?
If you are connected to the router and you are using a PlusNet router, use one of the links below to obtain the line stats - then post back here please.
Quote Physical Address. . . . . . . . . : xx-xx-xx-xx-xx-xx
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . :
IPv4 Address. . . . . . . . . . . : 192.168.1.71(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 29 September 2015 20:50:49
Lease Expires . . . . . . . . . . : 11 October 2015 13:23:13
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 311446757
DHCPv6 Client DUID. . . . . . . . :
DNS Servers . . . . . . . . . . . : 192.168.1.254
NetBIOS over Tcpip. . . . . . . . : Enabled
Message 2 of 2
(641 Views)
