I am here Again :(
- I am here Again :(
I am here Again :(
22-03-2012 9:06 PM
so has any one have any suggestions , maybe a new router not a thompson as its the only thing i aint changed .
yes JOJO i have swapped my router back to the second one PN supplied
Re: I am here Again :(
23-03-2012 8:02 AM
23-03-2012 9:23 AM
I've just run 3 tests in quick succession and got BT 1.76, MBS 4.1, Speedtest.net 8.46 (all Mbps.)
In general The BT performance tester seems back to its pre-update habit of slightly under-reporting compared with most others, but not by as much as it has done this morning!)
23-03-2012 9:31 AM
Feel free to give us a shout when you have...
23-03-2012 10:53 AM
PS jay G i only try to use the 2 speed-testers BT & speedtest.net i think they most reliable ones
23-03-2012 10:55 AM
23-03-2012 11:05 AM
have just run a speed test , and all is back to normal ???. so if PN run tests now it will show all is ok , but somewhere something is amiss Especially as Mr BT man couldn't find the problem.
as a matter of interest the new Routers Technicolor are they more reliable ?
23-03-2012 11:22 AM
i asked about swapping my router as as far as i can see its the only thing i haven't changed , he said you are trialing some new routers any chance i could test one for you
23-03-2012 11:32 AM
Quote he said you are trialing some new routers
Not quite right I'm afraid, we are but only for fibre customers on the 80/20 trial.
I can't state for certain if the outage was the cause, if you've rebooted you should have been able to reconnect, if not then a fault would need to be raised.
23-03-2012 3:36 PM
23-03-2012 4:49 PM
Also worth trying speedtest.net for a speed test, as BT speed tester has had its moments lately. If you continue seeing 5Mbps below your profile and it's a wired test then it would need a fault.
Jojo
23-03-2012 9:09 PM
see my speedtest results am on pcl-ag02.at mo but am going to restart router Again
23-03-2012 10:17 PM
checked running processes nowt wrong
26-03-2012 11:28 AM
How's it been? The speed test result I can see from Yesterday is showing 13274K throughput.
Jojo
26-03-2012 12:36 PM
but i dipped a bit last night , also my router errors have gone sky high again
