How can I achieve more consistent and faster wireless speeds?
- How can I achieve more consistent and faster wirel...
09-03-2013 10:46 AM
Would just like to start off by saying that after some initial teething troubles, I'm now very satisfied with the service I'm receiving from Plusnet. It took a few weeks, but I've now levelled out at a speed of 72mpps - which although not within +/- 1 mbps of the promised 80 mbps, I'm very satisfied with it all the same.
My only issue now is the much slower and inconsistent speed on wireless devices.
Standing right next to the wireless router, the speeds I get on my iphone, galaxy tab, ipad, etc all vary considerably and range between 20-35mbps.
I've looked into changing channels, but the channel I'm on isn't being used by many others.
Anyone know how to get speeds closer to those of the wired connection? I don't really want to fork out for a router with a stronger wireless signal
thanks
Plusnet wired connection speed:
thanks
Message 1 of 9
(3,796 Views)
8 REPLIES 8
Re: How can I achieve more consistent and faster wireless speeds?
09-03-2013 11:00 AM
Depends on the devices.
For some reason, Apple devices like the iPhone/iPad fail to get up to the max speed potential of 802.11n. Where as my iMac has no issues at all.
Message 2 of 9
(935 Views)
09-03-2013 11:07 AM
Quote from: matt8787 I've looked into changing channels, but the channel I'm on isn't being used by many others.
That doesn't mean it doesn't suffer interference from other (non-wifi) sources. So it's worth trying other channels.
Quote from: matt8787 Anyone know how to get speeds closer to those of the wired connection? I don't really want to fork out for a router with a stronger wireless signal
As AndyH says, the limitation is more likely to be the portable device. My iPhone achieves a throughput of about 17Mbps right next to my expensive, shiny, fast Asus RT-N66U router! Do you need 70Mbps on an iPhone?
Message 3 of 9
(936 Views)
09-03-2013 11:12 AM
Wouldn't know about iPhone/ipad. The new jellybean upgrade on android devices comes with power save ON as default, and there's no menu selection to turn it off. That inhibits the wifi speed. To turn powersave mode off, on your phone keypad, enter *#0011#, press menu, select wifi. The icon under power save state is lit. Touch the icon to turn powersave mode off. It made my galaxy phone yield the max speed on wifi. HTH
Message 4 of 9
(936 Views)
09-03-2013 11:16 AM
Quote from: Bright
Hmm, thanks - that saves me a fair bit of cash as I was thinking of buying that Asus (with a view to upping my wireless speeds).
Re the speeds needed on the iphone - would be nice if they ran closer to my wired connection speeds,
Message 5 of 9
(936 Views)
09-03-2013 11:23 AM
Quote from: matt8787 Re the speeds needed on the iphone - would be nice if they ran closer to my wired connection speeds,
Sure, but of course portable devices have to make compromises between performance, power consumption, size, heat dissipation, etc. They're getting faster, though. Put the cash saved on a router towards the next generation handset/tablet
Message 6 of 9
(935 Views)
09-03-2013 11:39 AM
Also, phones and tablets tend to only have a single antenna, which means they can only work with a single stream.
This will limit the devices to single channel (72.2mbps max), which has a realistic maximum throughput of about 40mbps.
The only way to get close to the theoretical 300mbps is to have devices which are MIMO capable and do channel bonding, which effectively means the device uses 4 channels simultaneously.
Message 7 of 9
(935 Views)
09-03-2013 4:51 PM
Quote from: kmilburn Also, phones and tablets tend to only have a single antenna, which means they can only work with a single stream.
Spot on fella
iperf is a great network tool for looking at the speeds across your networks as well.
My 72mb AP came back with a result of....
iperf -s -f M
Server listening on TCP port 5001
TCP window size: 0.08 MByte (default)
[ 4] local 192.168.0.14 port 5001 connected with 192.168.0.20 port 35501
[ ID] Interval Transfer Bandwidth
[ 4] 0.0-10.1 sec 42.0 MBytes 4.15 MBytes/sec
Tested with a Galaxy tab 10.1
running across my network to a wired Raspberry pi
Message 8 of 9
(935 Views)
09-03-2013 5:09 PM
On my iphone i get throughput of 42
i also upgraded my laptop with a intel ultimate 6300n wifi card so i can use the 5.0ghz band and i put a extra antenna in it
i also have the asus its a brilliant router
Message 9 of 9
(935 Views)
