High ping to router
- High ping to router
High ping to router
19-10-2009 11:20 AM
Ola.
I've just this minute joined and set up the router and got on the internet. First thing i did was check ping times to various places. Everything looks good except the first hop to the router; it's 100ms. Im using that thomson wireless one that comes with new orders.
I connect with a 3m ethernet lead. It's the same lead that i was using before to a netgear router at <1ms, so im thinking it isnt the lead, but i have no idea what else it is. Im running an MTU of 1492. I set up the connection by doing what it said in the guide. I cant think of any other information to give which might help.
Any ideas? Cheers
Any ideas? Cheers
Message 1 of 3
(917 Views)
2 REPLIES 2
Re: High ping to router
19-10-2009 11:45 AM
Thomson routers always have a high first ping. It is due to the way the firmware prioritises ping requests - nothing to worry about
Message 2 of 3
(367 Views)
19-10-2009 12:23 PM
I see. Ok thanks
Message 3 of 3
(367 Views)
