Help Please - New to Plusnet
- Help Please - New to Plusnet
Re: Help Please - New to Plusnet
28-09-2007 6:59 PM
Quote from: Oldjim It was something which came up on a Google search but checking again brought up your site from the google cache but still can't access it.
Thanks. I'll have a word with my hosting people.
28-09-2007 7:00 PM
28-09-2007 7:03 PM
Quote from: MikeWhitehead I can see that www.mypyrenees.com is registered until early 2008, but can't access it. How long has it been since you couldn't access it, and can you log into your hosting administration?
I last got into it a couple of days ago and then I tried about an hour ago and kept having trouble. There also appears to be a problem with the hosting people
28-09-2007 7:04 PM
Two weeks later I received a small refund (I'd paid in advance).
28-09-2007 7:06 PM
Still no change in the situation. Can you help please? .......
Grateful for any advice please.
28-09-2007 7:20 PM
28-09-2007 7:28 PM
28-09-2007 7:37 PM
28-09-2007 9:48 PM
If it is can you check your Outlook Express Settings.
As your account isn't activated would it be correct to assume you are still using your old ISP.
If this is the case the outgoing server would still be the one of your old ISP but the incoming mail for the PlusNet account would need to be the PlusNet server "mail.plus.net"
Assuming you have tried that have you tried using web mail to see if it is there.
Just as a last point - apologies if you have already done it - assuming the mailbox you set up is myname@username.plus.com have you set the account name in Outlook Express as "username+myname"
Still got problems!
28-09-2007 9:57 PM
"The message could not be sent because one of the recipients was rejected.........."
HELP PLEASE!
Re: More Problems - Desparate for Help pleas
28-09-2007 10:03 PM
- Open Outlook Express
- Go to Tools then Accounts
- Choose the account and go to Properties
In the servers tab, tick the "My server requires authentication" box and press Ok.
28-09-2007 10:09 PM
28-09-2007 10:38 PM
29-09-2007 12:02 AM
Alternatively the recipient may blacklist unknown senders - and your new PlusNet address will, initially, appear as an unknown sender.
Still got problems!
29-09-2007 8:25 AM
An unknown error has occurred Account mail.plus.net Server relay.plus.net Protocol SMTP Server Response 554 Please check your smtp Server is set to smtp.orangehome.co.uk
Can somebody advise please?
