Fiber up and running - 7MB down?
sanctuary
Greetings (Another thread from me, yes)
Basically, I've had Fiber optic since 4th of December, and have been working fine, just the problem being that I'm currently maxing out at 7MB's down (18MBs Up) and a BT test advised me to contact support (On the phone now)
I've read others posts that this is very low, even for the early days of an installation.
Any help appreciated.
Thanks!
10 REPLIES 10
sanctuary
Re: Fiber up and running - 7MB down?
1. Best Effort Test:  -provides background information.
Download  Speed
7.37 Mbps
0 Mbps 0 Mbps
Max Achievable Speed
Download speedachieved during the test was - 7.37 Mbps
For your connection, the acceptable range of speeds is 12 Mbps-0 Mbps.
IP Profile for your line is - 74.14 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
18.26 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 18.26Mbps
Additional Information:
The test result has indicated that you should contact your ISP for further assistance.
Please visit the FAQ if you are unable to understand the test results.
sanctuary
Telephone number:
01********
Phone exchange:
HORSHAM CARFAX
Estimated line speed:
2.0Mb (Accurate to within +/- 1Mbit) - Checked on 2012-12-04 21:19:49
Current line speed:
Not set
spraxyt
Resting Legend
Fixes: 75
Since this is a public forum I suggest replacing at least the 'number' part of your phone number with asterisks.
David
sanctuary
I don't keep a phone plugged in, so doesn't really matter to me 😛
adie:Quote
Fixes: 1,485
are you testing on a wired or wireless connection, what O/S are you using?
sanctuary
Wired, Win 7 64 Bit.
I've just tired to connect directly via the OR modem using PPPOE direct connection, and getting the same speed, so it cant be the router.
Some guy at plusnet is talking with a few guys about it now, gonna' rign me back.
adie:quote
Fixes: 1,485
Current line speed:
Not set
looks like that's your problem - that needs to match the 78mbps that the bt one.
probably artificially holding you back
sanctuary
Guy from Plusnet has raised a fault, as we couldn't find the problem.
Idk where to go from here, guess I'll report soon.
adamwalker
Fixes: 221
@sanctuary I can see that we've logged a fault report with our suppliers, I'd imagine we should have a response back regarding that before the end of today.
 Adam Walker
Chris
Legend
Fixes: 169
Wait a couple of minutes, log in to the router and disconnect/reconnect. Hopefully that's fixed it.
