FTTC Trial Speeds and VPN
- FTTC Trial Speeds and VPN
16-04-2010 12:49 AM
Hi All,
Today I got upgraded to FTTC, and on the whole, I'm really happy, I've gone from 1.1MB up to between 15-20MB, see stats here:
But my upload speed is really lousy, is that normal?
On another note does anyone have any idea how to get PPTP VPN's working on the Plusnet issued Thomson router, I've read a post about re-flashing it, but I'm a bit weary because of the modified config it's running?
TIA
xyberpix
TIA
xyberpix
Message 1 of 2
(652 Views)
1 REPLY 1
Re: FTTC Trial Speeds and VPN
18-04-2010 12:30 PM
Ok, so I solved the VPN problem, I just replaced the router with a Linksys WRT54GL, and it works a treat!
Message 2 of 2
(273 Views)
