F9/plusnet unlimated to plusnet premium speeds & traffic shaping
- F9/plusnet unlimated to plusnet premium speeds & t...
- « Previous
- Next »
Re: F9/plusnet unlimated to plusnet premium speeds & traffic shaping
22-03-2010 9:18 PM
Thanks spraxyt.
Its been going on for a while....
Noted it on the 10th March ....
Almost to consistent around 5mins ?![Huh Huh](/html/@E2297E1574AC8AB2FE5882A8865382BF/images/emoticons/huh.gif)
Quote from: Force9Original There's was a hugh time lag near 5 mins between DNS sync & getting PPP
Here the time stats..
DNS Link Information
Uptime: 0 days, 0:10:46
Modulation: G.992.5 Annex A
PPP
Type: PPPoE
Uptime: 0 days, 0:05:58
thank f9o
Message 136 of 140
(346 Views)
22-03-2010 10:09 PM
DNS
Uptime: 0 days, 7:02:34
-------------------------------------------------------------------------------- ( 5 min difference)
Internet
Type: PPPoE
Uptime: 0 days, 6:57:55
BTSpeedtest
speed for this service is 5500 k
Download speedachieved during the test was - 178 Kbps
For your connection, the acceptable range of speedsis 600-7150 Kbps.
Additional Information:
Your DSL Connection Rate :6769 Kbps(DOWN-STREAM), 1097 Kbps(UP-STREAM)
IP Profile for your line is - 5500 Kbps
I'll try changing gateways.
Edit
That gateway change seems to have got the speed back it its 5500 area...
Download speedachieved during the test was - 5454 Kbps
/i]
(Ticket ID: 32307358 if its helps)
Internet
Type: PPPoE
BTSpeedtest
Edit
/i]
Message 137 of 140
(346 Views)
23-03-2010 6:24 PM
Same 5 min delay again between DSL sync & PPP connection.???
DSL
Uptime: 0 days, 0:05:57
PPP
type: PPPoE
Uptime: 0 days, 0:00:14
Still heard nothing for a few days from Openreach or CSC on the main line fault.
so maybe time for a nudge on the ticket and highlighting this 5 min PPP issue again ....![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
DSL
PPP
type: PPPoE
Message 138 of 140
(346 Views)
24-03-2010 9:11 PM
Having read this thread it looks like this is almost identical to the fault on my own line. I've noticed just now that the higher tones of my connection are also much lower than the rest - this wasn't the case the last time I looked. Ticket ID: 32060215 see also - Trees fouling BT line in the ADSL2+ Forum. Unfortunately BT haven't been making the same kind of positive noises about the way to resolve my fault - instead I've been dumped onto a banded profile - sync speed 6656 Kbps with an SNR margin of 21.5 dB. I'm not prepared to accept this as a solution though - it doesn't address any physical or electronic causes of the fault.
Message 139 of 140
(346 Views)
25-03-2010 4:24 PM
Near 7 mins difference today
Are the gateways that congested
or is it something else???
[u]DSL
Uptime: 0 days, 0:08:29
--------------------------- (note the 7 min difference)
Type: PPPoE
Uptime: 0 days, 0:01:42
![Shocked Shocked](/html/@0AB4C7C43827ACF5B296F730FEC5B1DE/images/emoticons/shocked.gif)
[u]DSL
Type: PPPoE
Message 140 of 140
(346 Views)
- « Previous
- Next »
