Download speed up during 'open questions', down again when closed
- Download speed up during 'open questions', down ag...
Re: Download speed up during 'open questions', down again when closed
02-05-2015 11:01 AM
02-05-2015 12:01 PM
03-05-2015 10:49 AM
14-05-2015 8:31 AM
Kernal warm restarts rings an alarm bell or two - what version of firmware is the router on please?
Kevin
14-05-2015 9:23 AM
If you mean the software release, 8.4.4.J
Mick.
14-05-2015 12:48 PM
However that said, it is a Texas chipset at the exchange, the later firmware is purported to have better noise immunity and if Mick would like the firmware upgraded, I'm sure we could ask Plusnet to push it to him.
15-05-2015 9:24 AM
Mick.
15-05-2015 9:28 AM
15-05-2015 11:59 AM
Am not jumping on any "band wagon". Kernel warm restarts (however infrequent) are indicative of a software crash due to not handling some exception event. We both know this can be associated (all too prevalent) with the earlier firmware. That fact simply reminded me to enquire of the firmware level, something not thus far established. As you state and we've both experienced 10.2.2.B has been seen to be very much more stable in no end of situations. Indeed I'm now on 300 days of a continuous xdsl session since I did the upgrade last June. Ensuring that all is in the best possible state that it can be, is a sound approach to eliminating verified and potential sources of failure.
@Mick,
Firmware can be near permenant or readily upgraded (as advised by Mook) depending on if the product manufacturer makes upgrades and tools available. PlusNET can (on request) force a firmware upgrade of your router (down the wires) or you can do it yourself. Being out and about at the moment I do not have access to that link.
Kevin
15-05-2015 5:41 PM
Quote from: Townman Kernel warm restarts (however infrequent) are indicative of a software crash due to not handling some exception event. We both know this can be associated (all too prevalent) with the earlier firmware.
Sorry Kevin, that is a conclusion that you CANNOT draw. For example, a Kernel Warm Restart occurs when there is a Reboot. Other causes we do not know. You cannot conclude it was indicative of a software crash or due to not handling some exception event. In Mick's case this occurred once, 2 weeks ago.
There might be a multitude of things that might cause a reboot for example. Only a full analysis of the firmware would lead one to possibly draw some conclusions about Kernel Warm Restarts.
If you want an example of what happens with a software crash, it won't necessarily cause a Kernel Warm Restart - last week, my TG582n (albeit the USB version with 10.2.5.2 firmware) had a software crash which did not result in a Kernel Warm Restart. The crash was cause by BT maintenance with a rather ungraceful disconnect of my PPP session. The Router would not respond to attempts to reconnect a PPP session and the only solution was to force a (graceful) Reboot.
@Mick
Despite our different opinions on the possible causes, we'd both agree that upgrading the firmware should not be a bad thing. It has generally resulted in better performance albeit not always visible to an end user. Should you wish to proceed with that, post back before Monday and I'm sure Plusnet would arrange for that to be done for you remotely (it's too late today, the team that do it work office hours). I wouldn't suggest you do it yourself.
27-05-2015 12:25 AM
I haven't really been keeping tabs lately on the event logs. Looking just now it seems that the last time my router went 'linestate down' was just under a couple of weeks ago.
Mick.
27-05-2015 12:29 AM
27-05-2015 12:35 AM
So if I want to upgrade my router, how do I go about it?
I'm turning in shortly. I'll leave my PC on for about another 20 mins, check back then I'm done for the night!
27-05-2015 1:04 AM
27-05-2015 9:07 AM
So yes, let's go for for the firmware upgrade, why not?
"Make it so"
