Does it matter what router is used at installation?
- Does it matter what router is used at installation...
08-04-2013 12:15 PM
I already have a router(RT-N66U), so when the engineer comes to install will he care if I use that or does it have to be the Plusnet supplied one?
Message 1 of 6
(1,176 Views)
5 REPLIES 5
Re: Does it matter what router is used at installation?
08-04-2013 3:34 PM
Ah the "Dark Knight router" No, it doesn't need to be our route, but it does need to be FTTC compliant.
It looks like you should be OK to connect this one to the fibre modem though from what I can see here: http://www.asus.com/Networking/RTN66U/
Message 2 of 6
(627 Views)
08-04-2013 3:45 PM
You'll be fine. I use the N56U with fibre & there's no problem whatsoever. Just follow the "Quick Internet Setup" on the GUI as usual.
Message 3 of 6
(627 Views)
08-04-2013 4:34 PM
OK, as long as the engineer's not bothered ...
Message 4 of 6
(627 Views)
08-04-2013 5:03 PM
i used my Asus N56u when the engineer came although he left without me having any internet, although i did tell him he could go as i would set the router up later with all the details, it worked fine after putting in my PN username and pass into the router settings.
Message 5 of 6
(627 Views)
08-04-2013 5:23 PM
Great router the RT-N66U, got it mounted on the wall, i can pick up my wifi on my iphone way up the road from my house.
Message 6 of 6
(627 Views)
