DNS Errors
- DNS Errors
DNS Errors
27-01-2012 7:14 PM
I had my Plusnet Broadband activated today and its working perfectly on laptop with no connection problems. However on both desktops it will either connect for a few minutes (Although no websites load) then will cut off again and just give limited connectivity or the network will disappear completely. After doing Troubleshooting there is apparently no IP Addresses.
After doing a connectivity check on Thomson Gateway I get these messages:
Connectivity to Gateway (195.166.130.94) (Tick)
Connectivity to DNS Server 1 (212.159.6.9) X
Connectivity to DNS Server 2 (212.159.6.10) X
Could this have anything to do with no connectivity on other systems?
Thank you
Re: DNS Errors
27-01-2012 7:35 PM
You could try adding these and set to manual:
212.159.13.49
212.159.13.50
Does that fix?
See
http://www.plus.net/support/customer_service/using/settings.shtml
Tried Plusnet Assist
http://www.plus.net/assist/?utm_source=existingc
Re: DNS Errors
27-01-2012 7:46 PM
Re: DNS Errors
27-01-2012 8:31 PM
Usually problems reported are the other way round desktop works but laptop doesn't.
How do you connect your computers to the router - wireless or wired Ethernet cable? Often wired connections work fine but wireless is troublesome. Do any of the computers using a wireless connection use wireless 'n'?
David
Re: DNS Errors
27-01-2012 8:44 PM
Re: DNS Errors
27-01-2012 9:14 PM
Quote from: Jonathan1988 Any chance you can tell me how I do this? Sorry I'm a bit of a dunce when its beyond the basics (Although I'm sure this is fairly basic as well)
Key in
http://192.168.0.1
or
http://www.routerlogin.net/
and then user name/password
if not set default on Netgear is
admin/password
Click on Basic Settings
Re: DNS Errors
27-01-2012 9:31 PM
Re: DNS Errors
27-01-2012 9:46 PM
Re: DNS Errors
27-01-2012 10:35 PM
Re: DNS Errors
28-01-2012 12:20 AM
Is your laptop also connected wirelessly to the router? If it is are you able to connect to the router using a cable? Changing wireless settings is easier if you are not using them live.
Which version of Windows do you have on your desktop computers, and are they 32 or 64 bit? Ditto for the laptop.
David
Re: DNS Errors
28-01-2012 12:48 AM
Laptop works through wireless but can also connect through Ethernet which isn't possible with desktops due to distance.
Laptop - Vista X32
Desktop 1 - XP X32
Desktop 2 - Win7 X64
Re: DNS Errors
28-01-2012 2:09 AM
These settings can be changed by logging into the router, going to Home Network then clicking WLAN (centre) and Configure (top right). Click Apply to save any changes.
If those changes don't fix the problem I would also be inclined to try WEP encryption though that shouldn't make any difference if the desktops have WPA drivers installed.
David
Re: DNS Errors
28-01-2012 9:13 AM
Also, you can compare how many neighbouring wireless networks the laptop can see vs. how many the desktops can detect. I'm guessing the laptop will be able to see a few (assuming some of your neighbours have wifi) but the desktops don't have as good wireless and won't see as many.
Re: DNS Errors
28-01-2012 9:41 AM
The above is also true the laptop downstairs can pick up a few houses away signal and all BT Openzone networks however desktop upstairs can only pick up talktalk next door.
Re: DNS Errors
28-01-2012 9:51 AM
