DIsconections authentication issue
- DIsconections authentication issue
07-01-2011 12:34 PM
Hello my time with plusnet has been great until about 9 pm last night.
My connection will suddenly drop due to a authentication issue
each time this happens my connection gets slower and slower.
I have not changed my password.
My router is always on
No idle time out
I have tried using the master socket and a new filter
I have changed nothing to get this authentication issue
I phoned the support line but my phone line cut out.
_________________________________________________
Link Information
Uptime: 0 days, 0:10:24
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,616
Output Power (Up/Down) [dBm]: 12.5 / 19.5
Line Attenuation (Up/Down) [dB]: 19.0 / 33.0
SN Margin (Up/Down) [dB]: 25.0 / 11.5
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 26 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 8 / 0
FEC Errors (Up/Down): 0 / 221
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
__________________________________________________
No idle time out
Link Information
Message 1 of 6
(885 Views)
5 REPLIES 5
Re: DIsconections authentication issue
07-01-2011 12:44 PM
HI Dwivvc,
I've match the PN profile to the BT one at 6500k. You should shortly see the increase in speed to reflect this.
Jojo
Jojo
Message 2 of 6
(491 Views)
07-01-2011 12:47 PM
Hi and thanks for the quick response
Do you have any idea why I keep getting disconnected due to the authentication issuse?
As it just happened again and I have no idea why
Thanks again
Thanks again
Message 3 of 6
(491 Views)
07-01-2011 12:50 PM
Hi Dwivvc,
Tell me exactly what happens and how you get back on line. Also, what router are you using?
Jojo
Jojo
Message 4 of 6
(491 Views)
07-01-2011 12:59 PM
I will be browsing online and suddenly I will be taken to the routers gateway page Where the message "authentication failed" will come up. I will then try to connect again but it will carry on saying "authentication failed"
The only way I can get online is if I run the routers set up again.
It's the Tompson Speed touch router that came with my BB order.
Product Name: ST516
Serial Number: CP0949DTSDS
Software Release: 7.6.10.0
Software Variant: KF
Boot Loader Version: 1.0.8
Product Code: 3594263A
Board Name: BANT-V
EDIT: Happened again I uploaded a picture of the message
Product Name: ST516
Board Name: BANT-V
Message 5 of 6
(491 Views)
07-01-2011 1:50 PM
Hi Dwivvc,
It looks like the router is factory resetting itself. I've ordered a new one for you.
Jojo
Jojo
Message 6 of 6
(491 Views)
