Continued bad performance on PlusNet Pro
- Continued bad performance on PlusNet Pro
- « Previous
- 1
- 2
- Next »
Re: Continued bad performance on PlusNet Pro
25-05-2010 7:04 AM
Matt,
I just did another BT Speed test and overnight my line profile has settled to 14000kbps. This is the best it has ever been! The modem is still attached to the normal master socket, not the test socket as i did not want to take the faceplate off the master socket.
Michael
Michael
Message 16 of 21
(679 Views)
25-05-2010 9:55 AM
Well I certainly hope it stays there, though the fact that it's up and down so much is slightly worrying. See if it holds for a while I guess, let us know and I can do some more tests if we see more drops in speed.
Message 17 of 21
(679 Views)
25-05-2010 10:56 AM
Hi Matt
Let's hope it stabilises now.
Made a small mistake this morning - too early!
The BT Speedtester is still reporting a profile of 6000kbps but the downstream connection rate is reported as 16550kbps which matches the figure on my router.
Am I right in thinking that once this remains there for a few days then the profile will update itself?
Michael
Michael
Message 18 of 21
(679 Views)
25-05-2010 11:11 AM
I hope so - I've changed the profile on our side to match (14000 at the moment) but it would have updated most likely today anyway. You might need to disconnect/reconnect the router to see the new speeds though.
Message 19 of 21
(679 Views)
25-05-2010 1:45 PM
Thanks Matt
Will check it out later when I get home
May be a bit reluctant to unplug the router again though as the disconnections appear to have been the cause of the problem on the first place!
Cheers - will post back in a few days with some more solid results.
Michael
Michael
Message 20 of 21
(679 Views)
25-05-2010 1:53 PM
You don't need to unplug the router, within the web interface there should be a connect / disconnect button.
Message 21 of 21
(679 Views)
- « Previous
- 1
- 2
- Next »
