Constant disconnects since moving to ADSL2
- Constant disconnects since moving to ADSL2
20-11-2009 3:06 PM
Is it normal to be receiving constant disconnects when you move to ADSL2? I can't stay online for even an hour before the connection goes and it has to reconnect. It has taken me 20minutes to manage to get on line here to just type this message (and will probably disconnect again when I click "post")
The line was moved over yesterday but it is basically useless at the moment.
Message 1 of 9
(2,375 Views)
8 REPLIES 8
Re: Constant disconnects since moving to ADSL2
20-11-2009 3:52 PM
is it your sync to the exchange or the connection to plusnet network that's droping?
Message 2 of 9
(799 Views)
20-11-2009 4:22 PM
Hi, appears to be sync with the exchange
Message 3 of 9
(799 Views)
20-11-2009 4:25 PM
are you using the plusnet thomson router? if so can you follow this guide and grab your line stats so we can get an idea of your line
http://www.kitz.co.uk/adsl/frogstats.php#58 ( remember to use a captial A in Administrator when loging into the router)
Message 4 of 9
(800 Views)
20-11-2009 4:38 PM
Using a belkin router which supports adsl2+ I did order a plus one but they haven't even dispatched it yet.
Message 5 of 9
(800 Views)
20-11-2009 4:45 PM
your router should be on the list in the above link to grab the line stats.
also its worth trying a quiet line test if your line provider is bt use this (Dial 17070 and select option 2.) if you do get crackles and pops dont use the auto system get through to a operator and get them to confirm they hear the noise on the line and dont say anything about broadband just log it as a voice fault
Message 6 of 9
(800 Views)
21-11-2009 11:00 AM
Sorry for not responding last night, I gave up and went to the pub!
Changed router this morning and so far I have managed to stay on for 1 hour which seems to be an improvement. Also reading up on the Belkin I was using (F5D7632-4) I believe there maybe problems with it and ADSL2+ (not 100% sure on that though)
Stats anyway so you can see and advise (as I havent got a clue what they mean)
ADSL Link Downstream Upstream
Connection Speed 10716 kbps 445 kbps
Line Attenuation 30 db 8 db
Noise Margin 9 db 23 db
Message 7 of 9
(800 Views)
Re:Constant disconnects since moving to ADSL2
23-11-2009 1:16 PM
Hi floodster,
Is the connection remaining stable with the other modem? Sounds from your previous post like this could be the issue.
Message 8 of 9
(800 Views)
01-12-2009 3:11 PM
might be worthwhile changing protocol from PPPOA to PPPOE...I was suffering a lot of dis-connections on my Linksys WAG354G, and when I dd switch over had PN report the connection problem seemed to have stabilised....
Message 9 of 9
(800 Views)
