Connection Problems
- Connection Problems
Re: Connection Problems
19-10-2014 6:11 PM
21-10-2014 9:20 PM
[BEFORE RESET]:
20/10/2014
Link Information
Uptime: 1 day, 16:13:48
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,108 / 8,568
Bandwidth (Up/Down) [kbps/kbps]: 1,112 / 7,864
Data Transferred (Sent/Received) [MB/MB]: 61.34 / 411.87
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 22.5 / 40.0
SN Margin (Up/Down) [dB]: 5.5 / 8.0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 36 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 185 / 7,299
HEC Errors (Up/Down): 121 / 11,862
PLUSNET
Always on broadband xDSL
Estimated line speed:
Current line speed: 6.9 Mb
[AFTER RESET]
Link Information
Uptime: 0 days, 0:38:25
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,100 / 8,504
Bandwidth (Up/Down) [kbps/kbps]: 1,107 / 8,503
Data Transferred (Sent/Received) [kB/kB]: 69.00 / 118.00
SN Margin (Up/Down) [dB]: 6.0 / 6.0
CRC Errors (Up/Down): 6 / 35
HEC Errors (Up/Down): 5 / 129
Download speed increased after the reset but it didn't last long.
A ten minute burst of REIN around 1pm TODAY [21/10/14 ]knocked it back down to under 4Mb.
CURRENT figures:
Thomson Gateway
Link Information
Uptime: 0 days, 7:37:24
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,044 / 8,412
Bandwidth (Up/Down) [kbps/kbps]: 1,043 / 5,176
Data Transferred (Sent/Received) [MB/MB]: 21.06 / 249.97
Output Power (Up/Down) [dBm]: 12.5 / 19.5
SN Margin (Up/Down) [dB]: 6.0 / 15.5
Error Seconds (Local/Remote): 66,337 / 0
CRC Errors (Up/Down): 130 / 29,713
HEC Errors (Up/Down): 84 / 13,159
BTW TEST
1. Best Effort Test: -provides background information.
Download Speed
3.18 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 3.18 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 4.57 Mbps
Upload Speed
0.75 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.75Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Current line speed:
4.5 Mb
21-10-2014 9:58 PM
Interleaving seems to be off judging by the zero FEC errors. Interleaving being on should have made the ADSL a little more resilient to the interference.
Edit: fix typo
21-10-2014 10:31 PM
This is a bit disconcerting - synch speed is down and SNRM is well up. That could be due to there being REIN present when you resynch'd or the DLM is aggressively managing your line...
@CRT,
Can we have an update please?
Kevin
22-10-2014 12:20 AM
Quote from: ejs just disconnect [via] the router web interface.
I did that first but reconnected by switching the router off and then on again after about 20 mins.
22-10-2014 12:52 AM
Quote from: Townman
Hi Bookworms,
I've upload a routerstat graph of the period the synch speed went down and SNRM went up.
Current figures:
btwholesale.com
Download speed achieved during the test was - 4.45 Mbps
2. Upstream Test
Upload speed achieved during the test was - 0.42Mbps
Thomson Gateway
DSL Connection
Link Information
Uptime: 0 days, 11:16:22
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,044 / 8,172
Data Transferred (Sent/Received) [MB/MB]: 25.47 / 268.72
SN Margin (Up/Down) [dB]: 6.0 / 14.5
CRC Errors (Up/Down): 138 / 29,734
HEC Errors (Up/Down): 89 / 13,173
22-10-2014 11:02 AM
http://forum.kitz.co.uk/index.php?topic=9805.0
I hope the interference really has gone away permanently and you don't need to do it.
22-10-2014 1:44 PM
Quote from: PNRichardC At one stage it was suggested that you could use the radio as a direction finder to narrow down where the interference was coming from.
Yes, I've tried that thanks!
The signal was fairly consistent along the whole route of the wires and cables that run parallel beneath the pavement for several hundred yards.
I've a feeling it could be coming from the mains wiring somewhere along the street, but I don't really know.
As it is now very intermittent, I think the chances of tracking it down for definite are rather silm.
22-10-2014 1:53 PM
Hi Bookworms, sorry not to have got back to you sooner, there wasn't, at the last time I read, an awful lot I could add at the time, but more recent posts are completing the picture a bit more.
Just before I address a few specific points, just a reminder for any other readers (and/or posters) in this thread, that you are familiar with how to do graceful disconnects/resyncs using the Disconnect Method as mentioned in reply #15 Always use that method even if all you want is a resync. It's worth remembering that DLM takes account of errors as well as drops in sync and in some circumstances it could take just that one incident to cause DLM to raise the Target SNRM or band the speed which you certainly don't want, as if the REIN problem isn't enough already. So far, such extra problems have been avoided.
I take it that was an RF3 filter the engineer fitted? (reply #48) as well as the Mk.2 vDSL plate - this having a common-mode filter - all good stuff and will help, but this interference reducing your DS margin by 10dB is severe.
Did you not mention the Open cabinets etc to the engineer when he came?
Just looking at the stats again, I see a small effect on the Upstream. Are you plotting the Upstream SNRM in Routerstats? It would be interesting, just for the record to see the corresponding Upstream alongside the downstream which may just provide a little more information. Other than that, I see little point in graphing it continuously as it won't yield any further additional information thereafter.
What would also be of more significant interest at this time would be some Bits/Tone plots.
A normal daytime one - ie when you are synced at high speed with your typical ~6dB SNRM.
A daytime one when the Interference appears (I assume it causes a resync everytime from your posts, so sync speed will be lower)
A daytime one synced at the lower speed when the Interference has gone away/is not present.
If possible, a late evening one where you are synced at the high speed from daytime, not having a sync loss caused by the Interference earlier in the day.
In addition to those plots, for each of the above, Diagnostic results from the BTw Performance test (ignore the red preamble except make sure no other programs are using the Internet) and at the end of the first run, click the Further Diagnostics button, enter just your Phone number and Run the Further Diagnostics Test.
Do a Copy and Paste of the results and post here (no need to grab an image).
I'll just post this and do another post on REIN tracking shortly.
22-10-2014 2:24 PM
Quote from: Anotherone Did you not mention the Open cabinets etc to the engineer when he came?
Oddly enough, I again reported an open cabinet door to BTO's fault reporting number only yesterday.
The guy on the other end checked it against their maps and confirmed that it was in fact a Virgin cab and the BT one was located several metres away from it.
22-10-2014 2:41 PM
22-10-2014 2:49 PM
BTo advised me to phone the local council about the cab, which seemed a bit odd.
As for the rest of your points, I will absorb them and reply later, though I think I did post the BTw diagnostic results in one of my posts yesterday.
22-10-2014 5:17 PM
They don't have to be (can't be) all on the same day, well very unlikely anyway!
22-10-2014 6:07 PM
Quote BTo advised me to phone the local council about the cab, which seemed a bit odd.
Many councils have public safety responsibilities and will react to reports of an open cabinet which may expose mains connections. Same applies to street lighting poles which have live cables behind an inspection door just above ground level, these can be 'brushed' off by minor traffic impact. The more hassle to the offending owner the better chance of a swift repair, especially as once notified the owner is wide open to negligence claims. I hope you can track down your infuriating problem, good luck!
22-10-2014 6:23 PM
