Cisco Access Control List.
- Cisco Access Control List.
05-03-2014 9:51 AM
Hi, Do we have any Cisco engineers on here?
I am having trouble with my ACL and for the life of me, dont seem to be able to get it right.
I have an FTP server running on server 2008 set up on 192.168.1.175/24.
I can browse from other devices inside the LAN to ftp://192.168.1.175 however I can not access it externally from the WAN.
I have added the Extended ACL 101 in place which "should" allow access to ports 21 and 20 but I still cannot get through to the FTP server. I have applied the ACL inbound on my Dialer 1 interface which is connected to Plusnet.
Any thoughts?
adie:green removed ip address
Any thoughts?
Quote dot11 syslog
dot11 ssid AGETNET_DOMAIN
max-associations 15
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0
dot11 ssid AgerNet-Domain
authentication open
infrastructure-ssid
ip cef
no ip dhcp use vrf connected
ip dhcp pool DSL_DHCP
import all
network 192.168.1.0 255.255.255.0
dns-server 212.159.13.49 212.159.13.50
default-router 192.168.1.1
ip name-server 212.159.13.49
ip name-server 212.159.13.50
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
switchport access vlan 2
speed 100
pppoe enable group global
pppoe-client dial-pool-number 10
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
description AGETNET_DOMAIN
no ip address
ip nat inside
ip virtual-reassembly
no dot11 extension aironet
encryption mode ciphers tkip
ssid AGETNET_DOMAIN
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.
54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description INTERNAL NETWORK
no ip address
bridge-group 1
interface Vlan2
description WAN LINK
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
interface Dialer1
ip address negotiated
ip access-group 101 in
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 10
ppp authentication chap callin
ppp chap hostname
ppp chap password 0
interface BVI1
description $ES_LAN$
ip address 192.168.1.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 FastEthernet0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static 192.168.1.175 interface Dialer1
ip access-list extended NAT
permit ip 192.168.1.0 0.0.0.255 any
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 101 permit tcp any host link:csa removed eq ftp
access-list 101 permit tcp any host link:csa removed gt 1024
access-list 101 permit ip any any
snmp-server community public RO
snmp-server community private RW
bridge 1 protocol ieee
bridge 1 route ip
end
Message 1 of 3
(1,418 Views)
2 REPLIES 2
Re: Cisco Access Control List.
15-06-2014 10:01 AM
Nat configurations isnt OK.
You have to exactly point to what IP ftp goes translated.
But the best way is to get 2x public IPs, one for your server ftp, second for internet NAT.
Allow ftp port 20 too, this is for ftp data ...
UD
UD
Message 2 of 3
(514 Views)
15-06-2014 7:01 PM
Do you actually need to use FTP, if it's a Linux server you might be able to use something like SFTP (FTP over SSH) in it's place, which would be easier to setup as well as more secure.
Message 3 of 3
(514 Views)
