Cannot get on to my router homepage
- Cannot get on to my router homepage
01-01-2015 4:17 PM
Hi- I have a Thompson 585 router.
Recently I have been unable to get on to the router Gateway Home page. When I type in 192 etc the connnection times out. I had also bookmarked the homepage and the bookmark doesn't work either.
I have no real need at the moment to go to the Gateway home page but I may need to do so in the future.
I have not to my knowledge changed the address of the homepage.
I have recently changed my contract from a 10GB limited one to an unlimited one, might that have something to do with it?
I used to be able to get on to the homepage without any problem.
Message 1 of 5
(956 Views)
4 REPLIES 4
Re: Cannot get on to my router homepage
01-01-2015 5:48 PM
A reboot of the router should do it....switch off at the plug...wait 10 seconds....switch back on.
Ian
Ian
Message 2 of 5
(558 Views)
02-01-2015 12:26 PM
That's odd. If you open a command prompt and type in 'ipconfig' what does the default gateway show as?
Nope, shouldn't make any difference.
Quote I have recently changed my contract from a 10GB limited one to an unlimited one, might that have something to do with it?
Message 3 of 5
(558 Views)
03-01-2015 5:30 PM
Thank you both for answering- I tried turning it off and then back on again as suggested and it worked. Should have tried that first anyway. Thanks again.
Message 4 of 5
(558 Views)
05-01-2015 9:23 AM
Message 5 of 5
(558 Views)
