Can we buy microfilters from Plusnet?
- Can we buy microfilters from Plusnet?
03-01-2016 6:09 PM
Hi all
Is it possible to buy these from PN?
I know you can get them from the likes of ebay but I'd rather get the originals from an official company instead of some cheap make from some anonymous seller.
Thanks.
Thanks.
Message 1 of 9
(1,633 Views)
8 REPLIES 8
Re: Can we buy microfilters from Plusnet?
03-01-2016 6:13 PM
I thought that Plusnet were offering to send you more for free, at the time the Hub Zero was launched (which was only supplied with one microfilter).
Message 2 of 9
(1,030 Views)
03-01-2016 6:19 PM
The only router I've got is the Technicolor one (since 2013) and I remember receiving 2 of the filters at the time. I'm just wondering if we can get some more; obviously at cost.
Message 3 of 9
(1,030 Views)
03-01-2016 6:22 PM
I've got piles of the things! (All good designs, the rubbish ones get binned)
Message 4 of 9
(1,030 Views)
03-01-2016 6:28 PM
Do you have a master socket that's suitable for a filtered faceplate, instead of using plug in microfilters? You need the NTE5 type of master socket.
Message 5 of 9
(1,030 Views)
03-01-2016 6:57 PM
Thanks HPsauce
And yes, my socket's the NTE5 one.
Message 6 of 9
(1,030 Views)
03-01-2016 8:27 PM
Filtered faceplate is the way to go, specifically the latest VDSL ones that work equally well with ADSL and are a very clever design.
The main problem is that, due to Royal Mail size rules, filters cost far more to post than to buy. I'd happily give them away to anyone who can collect them.
They "just about" fit within the "Large Letter" (max 25mm thick) category so you can post them for under a pound.
Message 7 of 9
(1,030 Views)
04-01-2016 1:10 PM
Hi Cagney1994,
We don't sell those separately but these are widely available from lots of retailers and don't tend to vary in quality that much unless you do want to consider trying a filtered faceplate which are a favoured solution by many.
Message 8 of 9
(1,030 Views)
04-01-2016 3:33 PM
Just a very slight caution re filtered faceplates.
BT will be introducing a new NTE5C faceplate very soon (early 2016?) which is a very different design for "toolless" installation.
This will, I understand, not be compatible with current equipment, apart from the wall-plate/backplate. And extension wiring will not be connected to the faceplate but to the rear section in some way.
So, easy to install for engineers but if, for whatever reason, you get one existing interstitial/replacement faceplates won't fit.
Message 9 of 9
(1,030 Views)
