Can this postcode get FTTC?
- Can this postcode get FTTC?
16-10-2012 8:02 PM
Hi All
I have a customer who has a premises in NR7 0ET (Norwich). I've done a check and it appears FTTC is in the area. My question is can anyone tell if this is available (with Plusnet or whoever can supply - they are currently plusnet but happy to change to get better speeds).
rob
rob
Message 1 of 4
(1,006 Views)
3 REPLIES 3
Re: Can this postcode get FTTC?
16-10-2012 10:52 PM
From a quick check on here http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=29017, it doesn't look promising...
As mentioned elsewhere
Of course, rather than getting BT Infinity when available, it's much better to use Plusnet..
Quote Having your area enabled for fibre is the first step to getting BT Infinity – depending on your particular line it may not yet be available to you.
Message 2 of 4
(537 Views)
16-10-2012 11:50 PM
depends which exchange http://www.superfast-openreach.co.uk/where-and-when/ shows 2 are taking orders THORPE and NORWICH WEST
FTTP 500 regrade from Tues 28th November
Message 3 of 4
(537 Views)
17-10-2012 8:18 AM
If you know his phone number put it in here http://www.dslchecker.bt.com/adsl/adslchecker.welcome as his cabinet needs enabling as well as his exchange.
Message 4 of 4
(537 Views)
