Can't connect to xbox live for an update
- Can't connect to xbox live for an update
27-12-2011 3:09 PM
Any suggestions anyone can make on this would be greatly appreciated.
I'm not a big online gamer - don't connect to Xbox Live that often, just use a wired connection via a Belkin N+ wireless modem and router to get updates. Anyway, now it's stopped working - it's connecting to the internet no problem, just won't speak to Xbox Live servers. The Xbox is telling me it's do to do with my MTU setting, that it needs to be over 1364. Having checked my router configuration, it is, and always has been.
I've turned everything off and on, factory reset everything and Plusnet tell me there's nothing they can do other than consult the xbox connection guide. Which I've done!
Any ideas?
Cheers, Steve.
Any ideas?
Cheers, Steve.
Message 1 of 3
(7,222 Views)
2 REPLIES 2
Re: Can't connect to xbox live for an update
27-12-2011 4:26 PM
Is your Plusnet firewall enabled and blocking it? https://portal.plus.net/my.html?action=firewall
Message 2 of 3
(338 Views)
30-12-2011 11:12 PM
Thanks Strat, hadn't considered that, but it isn't on.
Message 3 of 3
(338 Views)
