Broadband down ?, Javascript error message from BT. Looks like a Local BT outage
- Broadband down ?, Javascript error message from BT...
![](/skins/images/9CB56258D7158C6B17DAA1A86F840B88/responsive_peak/images/icon_anonymous_message.png)
11-04-2012 9:42 AM
11th April Wednesday morning 09:30
Happily browsing away for ages, then ......
Couldn't connect to any websites.
Same problem with two browsers.
Kept being diverted to BT FON webpage
Resorted to T-Mobile dongle.
It came good after less than 10 minutes without me doing anything.
Certainly more than 3 minutes, when I went onto Dongle.
![](http://img593.imageshack.us/img593/5568/screenshot20120411at093.jpg)
![](http://img405.imageshack.us/img405/9773/screenshot20120411at093s.jpg)
![](http://img827.imageshack.us/img827/5568/screenshot20120411at093.jpg)
![](http://img214.imageshack.us/img214/5568/screenshot20120411at093.jpg)
https://www.btopenzone.com:8443/home;jsessionid=spppg7mjgnp?CPURL=http%3A%2F%2Fcommunity.plus.net%2F...
Added:
It mustn't have been a PlusNet broadband problem, because I kept getting diverted to the BT FON website whenever I tried to access websites
Added:
Message 1 of 5
(2,408 Views)
4 REPLIES 4
Re: Broadband down ?, Javascript error message from BT
11-04-2012 10:04 AM
I'm not sure how a Java error page about an Openzone service is related to your broadband from us?
Your connection has been up for over 6 days at the moment according to our RADIUS logs so I'm not sure that the issue is on our side.
Message 2 of 5
(772 Views)
11-04-2012 10:11 AM
Thanks.
Hence the question mark.
Something was going on.
Whilst connecting to my normal websites.... every time...
I was diverted to the BT FON page, ( spelling is correct) which took a while, wouldn't connect to any others for 10 minutes.
Something locally BT perhaps ?
I've spoken to a tech guy this morning, who confirmed what you say.
Added:
It mustn't have been a PlusNet broadband problem, because I kept getting diverted to the BT FON website whenever I tried to access websites, so broadband getting as far as BT was working !
Added:
Message 3 of 5
(772 Views)
Re: Broadband down ?, Javascript error message from BT. Looks like a Local BT outage
11-04-2012 11:17 AM
You may have considered this already, but...
Are you using a wireless connection?
and, has your computer decided to connect to a neighbours homehub instead of your own network?
Whie I haven't used it (BT-FON) personally, that looks like the typical page you get when you connect to a public WiFi network that requires you to log on before you can do anything else.
Message 4 of 5
(772 Views)
11-04-2012 1:15 PM
I think you are right, thanks.
I do indeed connect to my router by Wi-fi.
I hadn't considered this at all.
I do have a nearby ( not close and low signal strength) BT Openzone transmitter (someone's home) but have never been able to connect in the past when I've tried it.
Excellent suggestion, thanks
Though why it should swap partway through a browsing session I wonder why.
This has never happened before to me.
Unless perhaps a very close neighbour connected at 9:30am, with a new setup, but not showing at the moment ?
I rang PlusNet, and fortunately was connected to a very mac savvy tech person, who suggested I removed BT Openzone from my preferred networks in Sys Prefs, which I did.
Thank you PlusNet BB Tech.
My current speed has dropped to a quarter of normal, Plusnet BB
![](http://www.speedtest.net/result/1887972503.png)
My iMac has been switched off and disconnected from the mains for a couple of hours now due to Lightning & Thunderstorms, I do have surge protection, but I prefer to unplug if at home. No power outage though this time.
After I've caught up with my emails RSS etc, I'll reboot the router.
Result.
Router rebooted, back to normal speeds
And, here's something new after router reboot...
Wi-Fi search showed more Network transmitters, including an extra BT HomeHub, so maybe it came online at 9:30am ?
SSID's 2 & 3 will be Bluetooth Apple wireless magic mouse, and bluetoothed mobile phone.
SSID 1 is wireless keyboard, which I don't use.
Result.
Message 5 of 5
(772 Views)
