Broadband disconnections
- Broadband disconnections
29-09-2015 7:20 PM
Hello
We have noticed our internet dropping out every now and then over the past 2/3 weeks. Is there anything that I or Plusnet staff could do to test our connection?
Nothing has changed on our end and as far as I'm aware the phone line isn't crackling.
Many thanks
Phil
Many thanks
Phil
Message 1 of 5
(748 Views)
4 REPLIES 4
Re: Broadband disconnections
29-09-2015 8:05 PM
That may not be classed as "frequent" but suggest you read this
http://community.plus.net/library/broadband/broadband-faults-guide-frequent-disconnection-fault-dcn/
Please post router stats.
Are you connecting via ethernet or wireless if the latter try via ethernet in case it is a wifi problem.
See if there are any changes going on at your exchange or even in your cabinet -eg is fibre new in your area
Message 2 of 5
(548 Views)
29-09-2015 8:31 PM
Thanks for the reply. I am connected via ethernet.
Uptime: 0 days, 17:06:10
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,616
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 12.0 / 20.0
SN Margin (Up/Down) [dB]: 16.0 / 6.5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 1 / 511
CRC Errors (Up/Down): 1 / 1
HEC Errors (Up/Down): 2 / 1
Fibre is going up in our area in October. Could this be the issue? Possible interruptions due to a new infrastructure?
dick:quote
dick:quote
Message 3 of 5
(548 Views)
30-09-2015 8:32 AM
It might be.
@CRT,
Can you provide a VR plot please?
@CRT,
Message 4 of 5
(548 Views)
01-10-2015 4:29 PM
A few drops showing. nothing overly concerning.
Message 5 of 5
(548 Views)
