Broadband Speed = Skype quality?
- Broadband Speed = Skype quality?
29-10-2013 11:02 AM
When I was with BT before Plusnet I did not have much of a problem with Skype vision and sound. I assume that the line from the exchange is the same so can it be the low broadband speed that I receive. Have a webcam built into my laptop and I was thinking of purchasing a quality attachment but wondered if the low speed will still give me problems, if not can you recommend a good webcam. Thanks.
Message 1 of 8
(1,255 Views)
7 REPLIES 7
Re: Broadband Speed = Skype quality?
29-10-2013 11:16 AM
Hi got2getatan,
Are you having any issues with using Skype on your connection at all? I've checked over your line and everything looks fine.
Please let us know if there is anything further we can help with.
Message 2 of 8
(681 Views)
29-10-2013 11:21 AM
What sort of speeds do you get?
Message 3 of 8
(681 Views)
29-10-2013 1:16 PM
Live out in the country so get below 2mb. Sykpe problems are - picture keeps breaking up and sound gets distorted. If new webcam would solve the issues what would you recommend. Thanks
Message 4 of 8
(681 Views)
29-10-2013 1:51 PM
What video quality do you have selected in Skype?
Message 5 of 8
(681 Views)
29-10-2013 2:13 PM
I should explain that it is my wife that uses Skype on her laptop, just asked her your question and she does not know. I think she just connects and hopefully everything is ok. I don't do Skype but if you tell me what to do or check I would be very greatful. Thanks
Message 6 of 8
(681 Views)
29-10-2013 2:25 PM
If your wife uses the laptop with a wireless connection to the router it would be worth trying a wired connection out to rules out the wireless being the issue.
I haven't a camera myself, but looking through the Skype help pages I found there are various settings for quality - check the video settings of the options. It would be worth trying the lowest quality.
Message 7 of 8
(681 Views)
29-10-2013 2:57 PM
Thanks, will try that.
Message 8 of 8
(681 Views)
